Did it properly.......
Sent my sump to NZ today to be sent back looking like below.
Looks like it should do the job. Holds about 9-9.5L.
PM me if anyone wants details. Basically cost me $800 including freight both ways. Only one I've seen with such good cooling fins.
  • 2 years later...
Yep, Bob's got it right. Racefab in NZ. Awesome workmanship and Rob is a lovely guy to deal with.
Only drama I had was NZ Post lost my sump when I sent it over. It eventually turned up but took a while.
Good thing about custom is you can put as many different drain points, breathers whatever you like in.
I bought an engine that came with a Trust sump extension on it and they're crap, wouldn't even contemplate it nowadays!
How are they crap?
Sorry to offend.....
When I say crap I mean collectively as a package I believe there are better options for not much more money. This is totally in my opinion based on having had both Trust and a modified sump, feel free to have your own.
My thoughts are why spend $450 on the Trust extension, plus another $250-300 (??) on getting a good welder to weld it on without warping the sump when for another $200-$400 you can get a fully custom sump with worthwhile volume gains and improvements to oil movement without lowering your ground clearance.
At the end of the day you choose what works best for you.
Yeah that is one thing i have to say is it does lower the ground clearance a little.
my car doesn't sit stupidly low so its ok but that is a good point if your a drifter or something with a car that sits on the sills then you could have an issue if you hit something solid haha.
I had a Trust sump and got rid of it for a Performance Metalcraft sump. Much larger capacity and and as has been said, no ground clearance issues. Given he motor is in an S14 it has massive clearance issues with the Trust extension. Leon at Performance Metalcraft was able to custom make the sump to my requirements and it fits like a glove
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
