ok so the car in subject is a 1989 32 gtst
aircon dosnt work, need a bit of guidance from someone who knows more about electrics than me so i dont have to tip too much money into it
but must fix before summer hits!
ok so i have had the system re gassed with dye to find the leak, no leaks yet but the system is not yet operational. i assume i will have to replace something but thats the easy part.
the problem is my compressor and thermos are not switching on. i can hotwire it from the battery and switch the compressor on though so it does work.
i have had the pressure switch checked and their was another switch checked i think and that side of things work. i assume now that my aircon headunit itself has something broken in it, i was thinking next to just replace it and hope for the best.
is their something else electrical in the system though that i need to look at, or have looked at?
also does anyone have a wiring diagram for it?
https://www.sau.com.au/forums/topic/413008-aircon-and-how-to-fix/
Hey Glyn, do you have an aftermarket ECU ?
Quality units like Haltech or Vipec, there is a setting in these that can prohibit AC.
Likely not your problem but worthwhile being aware.
Also i seem to remember you can get a daig code out of the AC headunit.
Worth searching the forums for.
Obviously checked fuses ?
Just found many threads but this was in one of them.
Climate Control Diagnostics R32
The climate control has a diagnostic mode.
Enter the diagnostic mode by pressing the OFF button for five seconds within ten seconds of turning the ignition on.
Sensor check
Sensor check is selected by pressing HOT switch (the red triangle) while in diagnostic mode. The microcomputer detects whether each sensor input signal is within correct parameters. The results are displayed on the screen.
If normal, a "20" is displayed.
If abnormal the failed sensor number is displayed. The sensor numbers are as follows:
20 - all is normal
21 - outside air sensor
22 - Inside air sensor
23 - Water temperature sensor
24 - Intake temperature sensor
25 - Sunload sensor (small sensor on the left hand side of the dashboard near the windscreen)
26 - PBR
27 - Refrigerant temperature sensor
This should tell you if any of your sensors are faulty
Link:
http://skylineowners...thread.php?t=47
hope this helps.
yeah i came across that a while ago, all was normal so the sensors seem to be working,
also side not i was wandering what 25 was... saw it the other day and i saw the electronics when the sun hit it and was thinking some model had auto headlights :P
all fuses are fine yup, and i have a nistune board, doubt that would do anything?
my sparky at work said he wanted to test all connections on the back of the unit and work backwards from their but thats allot of time and money, would be faster with a wiring diagram.
Fixed mine, turned out that the ecu was holding it back.
The ecu has a few states which it wil turn the ac off, most are safety related, but one of them is when you want full power out of your engine it will quickly switch the compressor off to minimise the draw.
I suspect when the nistune went in this was altered or something, mine was keeping that switch off. We rewired this so it listenes to the ac head unit not the ecu on that one. And bam Crispy cold air ready for summer
Hmmm does a Power FC do the same and prohibit the air con?
I haven't had air con for about 2 years now :(
When I first tried to fix it, I believed that it was a faulty compressor, which I had that replaced for a 2nd hand unit. Got the gas refilled, and thought I got the air con to work again as it was icy cold on the way back from the air con workshop, but after 15 odd so minutes of driving it never stayed cold and the air was like the temp of a normal fan.
I've been thinking that it's been the 2nd hand compressor all along, like maybe because it was 2nd hand the seals were brittle and cracked, so it leaked again. Never thought to take it back as I didn't want to spend more money recon'ing the thing.
But with this thread coming to my attention, could I be off the right track, and in fact it could be linked to my Power FC?
Sorry to hijack lol, but it's all relevant!
Cheers,
Andy
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
