Thanks boys, yeah have done alot of reading an looking around, as it was a fully built motor and with 2000ks the old owner spun bearings broke 5 oil jets off... Haha so I don't wanna cross that path
I think the engine builder thinks I'm using a standard pump when I am using a n1 so I'm sure when I tell. Him he will say to put restrictors in
An N1 is hardly a high volume pump. Just a little bigger than stock. It IS the stock pump in a 25Neo.
The gears are actually smaller than the stock pump, it flow oil at higher pressure, not more of it.
It's not the stock pump for a NEO either, part numbers between Neo and R33 RB25DET's are exactly the same(15010-5L800) Whereas the N1 pump is (15010-24U01).
Source: Nissan Fast
Source: Nissan Fast
FAST is wrong on this one. Both of the standard Neo's I have have seen dismantled (including my own) have had an N1 oil pump. And several others membes of this forum have seen this also. There is the possibility that some did not have the N1 but it seems unlikely. Mine was a very early build Neo.
Yep. Wrong. All NEO 25DETs have N1 pumps from the factory. Still short nose crank though.
They have a higher oil pressure relief spring. Its a debate as to whether they flow more or not. N1 has a different tooth design though. It is 'waved' and not symmetrical.
  • 1 month later...
  • 5 years later...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
