Hey guys I need help to get myself 4X longer turbo studs M10X1.25X55mm long at least ( Precision 5558 turbo going onto stock mani with 12mm spacer plate), exhausted goin to autobarn, repco, supercrap auto and even bunnings in parramatta/auburn area in western Sydney, longest they have is 40mm even that in M8 size. Most of them have studs with the hex bolt head welded too. But I just need studs, cant be fked cutting head off etc. Where/what is the closest nut/bolt place in my area, google aint helping and I have uptil Sat wen I will be bolting my shit together, theres always these little bits that I realize I aint got...aaargh! Any suggestions/ exhaust places or what?? Pretty annoyed that supercrap /repco/ autobarn dont stock these. Not interested in GCG Inconel shit for 80bux and its not even long enough.. Ebay got stuff but its not local
https://www.sau.com.au/forums/topic/413023-long-turbo-studs/
The problem with using cheap studs not suitable for exhaust parts, it will bite you in the ass in the long run when they seize/weld up if you ever decide the turbo and exhaust parts off again. It's why the GCG Inconel studs are so expensive
Na, bolts will have to be the exact length to bolt in and hold tight, else use dodgy washers to fill up space.
Jez the guys fitting the turbo are Ron, Jase and Mick O (fab work), these guys dont have studs lol..
Jase, na not getting studs from Melbourne(Stao)
as he himself uses Supercheap Auto stainless studs which I cannot get. AU Falcon ones may do if I can find a wrecker close by.
Scotty, looked up Stainless Allthread -they have M10X50 threads (not studs, but still) maybe get those if all else fails.
Baah didnt think how hard it would be to find a piece of threaded metal..
The stock manifold has M12x1.5 thread. just buy 60mm long studs from Supercheap, cut the hex head off and there is the stud. They comes with Nuts too.
Oh is it really 1.5 thread, I just ordered 1.25 thread man, now I need to get new nuts.. Past threads I have been reading suggest 1.25?? And M10 not M12?? Confused here :S
Edited by rondofj
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
