Hello!
I have oil leaking/weeping from the front of this sensor just below and to the left of my oil filter. Can anyone tell me what sensor it is (oil pressure?) and if I should replace the whole thing? I have had no luck tightening the screw at the front which is where it is leaking, at the very front just behind the screw.
Thanks for any help
Rhet
https://www.sau.com.au/forums/topic/413032-rb25-oil-leak/
Your oil/water exchanger is in the picture, it might be leaking oil from there.
it was leaking from there but I replaced the seal and its no longer leaking that's on old photo, I'm actually watching it leak from the sensor with the engine running.
https://www.sau.com.au/forums/topic/413032-rb25-oil-leak/#findComment-6609000
Don't over tighten it, you might wreck the thread. Take it off, clean the oil off the thread on the sensor and in the water/oil exchanger with a can of brake or carby cleaner. Use some gasket sealer on the thread of the sensor to help seal it when you do it back up.
https://www.sau.com.au/forums/topic/413032-rb25-oil-leak/#findComment-6609035
I have only tried tightening the screw on the very end of the sensor not the whole sensor screwing into the block but yeah I didn't move it much and it didn't help. Do you have any idea what the sensor is? if i'm going to remove it i may as well replace it, id hate for it to leak if I cleaned it and put it back on
https://www.sau.com.au/forums/topic/413032-rb25-oil-leak/#findComment-6609061
It's leaking from the thread isn't it? You don't need to replace the sensor if it is.
Not the thread where it screws into the block no, the sensor itself is leaking from in front of the black plastic part behind the silver screw that's circled in the pic
https://www.sau.com.au/forums/topic/413032-rb25-oil-leak/#findComment-6609104
now I'm having an interesting and annoying problem lol, the new sensor fits in a 1 inch socket but the old one is slightly larger, a 26mm is to small and a 27mm is too big as is a 1 and 1/16! WTF it's driving me mad I think I'm gonna chuck vice grips on it if it's possible I'm so damn angry haha.
https://www.sau.com.au/forums/topic/413032-rb25-oil-leak/#findComment-6615403
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
