Hello
so it is generally agreed on this forum that the power limit for a stock bottom end rb26 on 98 is around 350kw...
now I know it all comes down to how its treated and tuned etc, but do we have any indication of the upper power limit of a stock bottom end rb26 on e85?
mine seems to be making healthy power and is going strong
my brother's is making 440kw on a stock motor and has been going strong for months
know of a few other stock bottom end GTRs making the low 400kws mark on e85
The Mercury Motorsport GTR is making a whopping 600kw on a stock N1 block with this fuel
so I ask you, what do we think the limit is....
this is more of a discussion rather than trying to figure out the exact number because it does heavily depend on treatment, tune, motor condition etc etc
What do you think? Do you know of any other stock bottom rb monsters? or have you seen high power stock bottom ends rb26s with e85 fail at a certain power level??
Discuss :)
Edited by usmair
https://www.sau.com.au/forums/topic/413047-stock-rb26-power-limit-on-e85/
depends on what its used for and the boost level, its common to make big power but i would guarantee unless its drag (full load for 9-12 secs at a time) etc a 500-600awkw gtr is not going to last many laps (1/2 hour at a time) in a circuit type situation...
The way its driven is the most crucial part. Thrash it and it wont last.
Squirts here and there should last.
Circuit probably wont last.
My own GTR is 402kw 22psi E72
Has only had dyno and drag time, 2 street cruises
Just have to be prepared if u want to push limits and it does let go u have to accept the fact.
Ur on 370kw now right?
Did u sort out the issue's u are having.
Yep agrees it depends on application and how it's treated.
I do have a 2.8L stroker fund put aside but would prefer not to utilise it if not necessary.
Mine is running well actually... Had a big cut in one if the piping.. Once that was replaced the boost and power was back to how it was before.
Still keen to chuck it on another dyno though... Anyone know of any awd dyno days coming up in Sydney??
Stick it on Jez's 2WD.
Unigroup is having one in December ive been told....would be good to see a few of the bigger HP cars around Sydney there on a level playing field
lets see if they make the power they all say they make
its a RWD dyno only but im sure we can get the front shaft taken out for such events
800hp, or there about - but having they are building a 3.2ltr for "when" it dies.
I think no-one is under any illusion there what will happen eventually, least of all the owners of it.
Its the age old saying, if you cant afford the rebuild then dont chase the power. The fuel being used is irrelevant when its a 15yo motor.
i was impressed when i finally got my r33 GTR, and just stuck a GTX3582r with 6boost manifold twin scroll. power fc with two z32 afm 2 hks bov vent back in, and intank Tomia pump. at the same 1 bar and a good tune stock injector at close to 8000 rpm the check light would flash (injector max out)
124 mph in the quarter dont remember the ET.
but i will never buy another gtst. lol
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
