Hello
so it is generally agreed on this forum that the power limit for a stock bottom end rb26 on 98 is around 350kw...
now I know it all comes down to how its treated and tuned etc, but do we have any indication of the upper power limit of a stock bottom end rb26 on e85?
mine seems to be making healthy power and is going strong
my brother's is making 440kw on a stock motor and has been going strong for months
know of a few other stock bottom end GTRs making the low 400kws mark on e85
The Mercury Motorsport GTR is making a whopping 600kw on a stock N1 block with this fuel
so I ask you, what do we think the limit is....
this is more of a discussion rather than trying to figure out the exact number because it does heavily depend on treatment, tune, motor condition etc etc
What do you think? Do you know of any other stock bottom rb monsters? or have you seen high power stock bottom ends rb26s with e85 fail at a certain power level??
Discuss :)
Edited by usmair
https://www.sau.com.au/forums/topic/413047-stock-rb26-power-limit-on-e85/
depends on what its used for and the boost level, its common to make big power but i would guarantee unless its drag (full load for 9-12 secs at a time) etc a 500-600awkw gtr is not going to last many laps (1/2 hour at a time) in a circuit type situation...
The way its driven is the most crucial part. Thrash it and it wont last.
Squirts here and there should last.
Circuit probably wont last.
My own GTR is 402kw 22psi E72
Has only had dyno and drag time, 2 street cruises
Just have to be prepared if u want to push limits and it does let go u have to accept the fact.
Ur on 370kw now right?
Did u sort out the issue's u are having.
Yep agrees it depends on application and how it's treated.
I do have a 2.8L stroker fund put aside but would prefer not to utilise it if not necessary.
Mine is running well actually... Had a big cut in one if the piping.. Once that was replaced the boost and power was back to how it was before.
Still keen to chuck it on another dyno though... Anyone know of any awd dyno days coming up in Sydney??
Stick it on Jez's 2WD.
Unigroup is having one in December ive been told....would be good to see a few of the bigger HP cars around Sydney there on a level playing field
lets see if they make the power they all say they make
its a RWD dyno only but im sure we can get the front shaft taken out for such events
800hp, or there about - but having they are building a 3.2ltr for "when" it dies.
I think no-one is under any illusion there what will happen eventually, least of all the owners of it.
Its the age old saying, if you cant afford the rebuild then dont chase the power. The fuel being used is irrelevant when its a 15yo motor.
i was impressed when i finally got my r33 GTR, and just stuck a GTX3582r with 6boost manifold twin scroll. power fc with two z32 afm 2 hks bov vent back in, and intank Tomia pump. at the same 1 bar and a good tune stock injector at close to 8000 rpm the check light would flash (injector max out)
124 mph in the quarter dont remember the ET.
but i will never buy another gtst. lol
