LOL looks like your the guniea pig. :)
Blew a late 1UZ on the dyno last night, the limit of its compressed powder rods was 300kw on ethanol. It made massive torque though before it fractured.
Eventually something will fail, the gamble is when and at what torque.
  • Like 1
Sorry to hear about the failure Scott, where were you tuning it?
Khaled, where are you getting yours tuned? Edge? I think your pushing your luck on a stock bottom end....once your around 400Kw on a RB26 and its a stock bottom end its no longer the tuner, some serious physics start to come into play, rod bolts stretch, big ends and piston pins start deforming, factory piston ring lands can only take so much.
Better talk to Barry about the costs of a forged bottom end before you fry it and end up with the car off the road and a big repair bill......your walking into high risk unchartered territory IMHO.
Then again you and Stef never listen to anyone anyway. :P
Edited by GTRPSI
Edge. I hope Barry isn't too pissed about the mess on the floor.
Luckily it was only at 3k, it would have made one hell of a mess at 7. No wonder they park that old Ford beside the dyno. lol.
  • Like 1
I never once said I wanted 400kw though? I was just curious to know how many more people have accomplished this since this thread has started.
Also quite a few people are running 400+ on a stock 26 on e85. Its amazing how strong these rb's are.
Edited by drgtr7
Your not that far away now on 98 correct?
Nah you never said 400Kw...but your going to end up around it by the looks of things if you go E85. :)
I thought i heard Stef mention your were fiitting a E85 sensor to yours at JAK (or am i mixing you up with someone else)?
Yes RB's are strong, but get the revs up and thats when the strain starts to show, note Scotts comments about the engine he lost on E85 at 3K, allbeit with 1UZ stock rods.
@ Scotty, What do you think it was, the slow burn of the E85 putting out too much cyllinder pressure/torque on the rods, what sort of numbers were seen around the RPM when it popped, or do you think the rod was stressed from a previous dyno run when at song and bound to fail on the next run?
Bah, its only oil and frag to be cleaned, as long as any metal didnt meet any customers cars nearby, probably hear all about it next week.
Is your EVO back on the road?
Edited by GTRPSI
My car makes 800nm on the Edge dyno, the Soarer was making 1200nm at 10psi. Torque is what kills rods I imagine, and this had it in bulk. It would have been stressed from the previous runs, but the sintered rods just fracture and let go, no bending etc like you would see on a forged rod before it failed.
Yes, the Evo is running, just a few small issues to sort out and I can fit the 1400's and tune it.
  • Like 1
  • 8 months later...
  • 2 years later...
Thread bump
Update on my stock bottom end.
made 480-500kw on JEM's dyno with a 8374 w 1.05 rear on e85
- Mild head work with small cams
- stock crank, rods and pistons
- stock oil pump and sump
Ran 10.7 @ 134mph on 28ish psi in Sydney summary with 8374. Probably could go 136-138mph in the winter....
Am now inthe processing of upgrading to a 9180 w 1.05 rear.
Depending on how brave I'm feeling I'll tell the tuner to cap the power at 570kw-600kw (on JEM's dyno). It should be good for 140-145 mph.
Long live the stock bottom end.
Lots of big power stock bottom ends floating around. Would love to hear updates on the setups, particularly with:
- power on workshop dyno (lets be honest these do differ quite a lot)
- turbo with rear housing and psi
- basic engine mods
- fuel
Cheers
  • Like 2
- basic engine mods
- fuel
Cheers
My first motor died after about 4 years with varying levels of power from 450kw to 550kw. It died a sad death when it dropped a valve guide (it had actually dropped 11 of them but the others had shot out the exhaust). Bottom end was still mint when it came out.
New motor has been going a few years with 520-567kw with a few different cam combos. Seems to love life and gets driven fairly hard at the track a lot and 1000m drags.
- power on workshop dyno (lets be honest these do differ quite a lot) 567kw on a dynapack hub dyno
- turbo with rear housing and psi Precision 6262 0.84 with just over 30psi
- basic engine mods mild ported head and smallish cams
- fuel United E85
  • Like 3
  • 3 months later...
Ok. Bit of an update
Car is now running an EFR 9180. Still factory Nissan bottom end with factory pump and sump.
On 35 psi it made 580kw on JEMs dyno.
Recent Sydney winter weather has been bumping up the boost and it's hit 39 psi a few times now and still survived.
On 39 psi you'd think it'd be 610-630kw on the same dyno....??
- fuel United E85
Up to 582kw these days (Mainline hub dyno), ran a 9.6 @ 146mph so power and speed match fairly well
Edited by SimonR32
  • Like 2
  • 7 months later...
Thread bump and update
So I ran 10.4 at 140.6 mph with the EFR 9180 at 2018 GTR festival. Turned it up to 11 for the next run and broke a rear shaft so only got one decent run.
Upon inspection of the Haltech data log we discovered the turbo was hitting 30 psi from 1 to 4th and would only see 35psi in 5th gear so safe to say I was a 50-60 KW short on the run. Profec B no good...
I now have boost by gear set up via an eboost2 and the the car has 37psi shoved down its throat with it tapering off to 34psi by redline.
Should help the MPH a bit I'd say
Ready to head back out to WSID once Sydney weather cools.
A 9 second pass with a stock bottom end and 34 getrag is the goal. Don't think it's ever been done before,  especially in the heavier 33 GTR.... ??
Still all factory Nissan parts from the head down
  • Like 2
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
