Hey, ive just recently joined the forums, as i did a search for some skyline related forums and came across this nicely looking one.
Im kind of in the process of buying a skyline something along the lines of an R32, and was wondering where i might go about my ways of getting one for a nice price.
Would it be better buying it privately? or through a distributor?
I'm looking towards getting rid of a sonata that's only done 60,000 k's it's a 96. Mac needs his skyline fix.
Thanks fellas for your time.
Mac
https://www.sau.com.au/forums/topic/41305-where-skylines-are-purchased/
www.perthcars.com - I purchased my car (96 R33 Series 2 Gts-t) and Paul (the owner) is a great guy. A few guys have purchased cars through him and many others get parts etc.
www.prestigemotorsport.com.au - Lots of people recommend Geoff. I've never used him, so I can't comment.
Good luck and welcome to SAU :)
Oh god, that is a nice ride. Nice indeed.
You wouldnt happen to be going on a chick named tahlias 18th Car cruise would you? she mainly posts on the antilag forums. if not i could probably get a routemap of the cruise if you are interested.
Yep, it mainly comes down to how much i could get for my car really.
umm yeah i wouldnt trust the braking and handling abilities of some of the OTHER cars attending that cruise :)
macma ring paul at autoworx, he is straight up and will be able to help you for sure even if it is to tell you that he cant bring an r32 in unless its an 89 model
and heck hopefully you can get an r33 if not just for the airbag/s
Macma....Regan has a couple of 32 4doors coming that look sweet www.dcimports.com.au
& Accents have R33 4doors starting from $17000 with 3 year warranty (drove a nice Grey one with a TV & GPS) try www.accentautos.com.au
& YES I know they are all four doors! but thats all I got at the moment :P
    • Don't turn down the limit yet. Put a mechanical pressure gauge on the car in the same spot and go and prove it.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
