Battery in the boot is complete!
Had no issues at all.
Here's a few crap night photo's. It tidies up the engine bay alot!
I didn't get a chance to paint that hold down clamp, that will be this weekends job.
  • Replies 193
Thanks a lot mate!
Yeah dude, that was most of the reason behind moving the battery to the boot as i wouldn't be able to fit a 3.5" intake there. Yeah the whole LHS of the engine bay will become the airbox, so i'll be able to do a nice intake with bugger all radius in the bend, if any at all. Once i get my new intake manifold to suit the Q45 throttle body i'll be starting the intake.
Edited by TimmyMA70
I test fitted my JMR headers today, I wanted to test fit them so i can order all the mandrel bends to make the mid pipe. They had a few minor fitting issues. Nothing I won't be able to iron out though :)
Cylinder 1 pipe was made a little too close to the alternator, we are talking millimeters. So I'll have to heat them up with the oxy and bend them a little.
I had to remove my AC lines to fit them, it was mainly the low pressure line that was fouling. Once I fitted them I put the lines back on, with a slight tweak you could get them to fit again, though I don't think I'm going to worry about it.
Thanks mate :)
If I eventually get off these 12hr night shifts I'll be able to get a bit more done. The next thing will be a 3" exhaust. I rang all the local exhaust shops and a few in Sydney, though most shops want $900 upwards for a 3" mild steel catback, keep in mind I'll be supplying all my own cat, resonator and muffler.
I thought about it and I might have a go at making my own exhaust. Order all the things I'll need from bestmufflers.com.
My oldies have a workshop with a 4 post hoist and a mig etc. So might give it a crack, I'll think about it for the next few days and make a decision.
Another minor update, it wasn't necessary, though it will make tuning a bit easier.
I originally thought the top cam gear was a fake, I later confirmed off RHDJapan that the top cam gear was Tomei's earlier design. So all good :)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
