I couldn't find specific information on where to source replacement FRONT bonnet struts in Victoria, so I am posting this to help somebody else out.
I found some following info here:
http://www.skylinesa...s-struts-in-wa/
WC34 Stagea Bonnet Struts
400mm long
370 newtons
Clip on angled ball , 10mm, both ends.
I just recently bought replacements which were Nissan Maxima 1995-1999. I got a few quotes to regass them locally and they were $100+ for the pair, so opted for some new ones.
I got mine from Auto and Industrial Gas Struts, pdf attached and link to Ebay Store. Price was $48 + $7.50 postage with metal ends like original, not cheaper plastic ends.
http://stores.ebay.c...sid=p4340.l2563
I asked some questions and this was their reply;
We know about Stagea import bonnet struts. Patrols are close , but slightly longer but only 340n, Maxima's are slightly different in shaft length etc
but work because they have the correct offset end on one end but they are stronger at 410n.
Apologies if already covered elsewhere, I did a search and couldnt find anything conclusive. Hope this helps somebody out.
Nissan Maxima Stagea Bonnett Struts Ebay.pdf
Edited by RS4StagMan
https://www.sau.com.au/forums/topic/413092-c34-stagea-bonnet-struts/
I think I did post up somewhere, but I also recently put maxima struts in mine...working well.
the rear is not so easy, I had to get my old ones regassed
That search engine is doing funny things.....
You did post that up Duncan you are right.....
http://www.skylinesaustralia.com/forums/topic/231951-bonnet-strut-part-numbers/page__p__4074895__hl__bonnet%20strut__fromsearch__1#entry4074895
I fitted them up and they fit perfect, 12mm open end spanner and 10 mins. They had "gassprings.com" and "410N" written on them.
What did the rears cost to regass?
yeah sorry I can't remeber an exact price but it was very reasonable...and better than the damn boot slamming every time I closed it :) under $100 from memory, so brand new ones for the bonnet are about half the price.
I am pretty sure the boot ones don't interchange with anything else, they are very specific to their mounting in the boot. Also, Nissan no longer have stock of them so regassing is the only option
Did you need particular info on how strong the struts have to be?
  • 5 years later...
Hello @RS4StagMan
Sorry for the update to an old post, but probably better than creating a new one... Maybe you can add this to your original post?
The rear boot struts are 700n for my 2000 RS4.
At least that's the pressure I had them regassed to and it opens the boot nicely.
(Initially tried regassed to 600n and it was a tiny bit better than before I had them regassed, but it wouldn't open the full way without help in the final extension. I guess that shows they loose around 100n in 15 years? Not sure how many opens that would be... But interesting for me at least. ??
Ian at Struts W.A in Perth is great if anyone is after a regas. Much cheaper than new struts! (Assuming you're aren't bent of have lots of nicks on the pipe this is an option).
He also supplied new front struts for my bonnet and pressured them to 400n. (My old ones were damaged and couldn't be regassed reliably)
Gif attached of it working.
Edited by jamesnorman93
Details of 600n attempt.
I just bought two second-hand pairs of struts, one pair each for the bonnet and boot, from SSS Automotive in Girraween (NSW).  Hopefully they’re still in decent enough condition.
For the bonnet at least, the generic ebay maxima ones are easy to find, drop right in and they work well. I must have replaced mine circa 2012 and they still hold the bonnet up very firmly.
The problem is the boot. Now that I have a good idea of the force, I remember trolling ebay years ago and finding a whole host of generic struts with various attachments on either end. So, on one end look for a ball mount, and on the other, it will require a bit of creativity to mount it to the tailgate.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
