Ok, so I just bought a brand spanking new set of project mu SCR rotors front and back and also a set of project mu M-spec (not available in Aus) pads all round too. I thought this brake set up would be pretty damn good for a road car, having slotted rotors and all......but boy was i wrong. I've had it on the car (which has only seen street use) for a month now, and recently partook in some spirited driving with some other GTR boys. After 15/20 mins of moderately hard driving, picking up speed then wiping it off, I really started to feel the brakes fade. Not a little bit, but a LOT. At one stage I had to brake very hard and almost drove off the side of a hill....When I eventually slowed down to park (moving at 5-10 kmh) I could not even stop the car. It kept rolling forward until it stopped almost on its own. I got out of the car and inspected the brakes which were billowing smoke, and were EXTREMELY hot. I have never shat myself so hard, nor have I been so disappointed in a purchase (that wasn't cheap) I was genuinely expecting more from. This was supposedly one of the best street/sport setups you could get for a GTR without an increase in rotor size/bigger calipers. What are your thoughts? I've considered upgrading to braided brake lines as well but that wont solve the fade or heating problems...
Edited by Iron Mike
If you have old shitty brake fluid that is then undergoing higher temps them before then you are probably boiling it and getting a soft spongy pedal yeah? I'd be doing that and making sure the pads are sliding freely then re-check before worrying about the new hardware
The rotors will be lighter than stockers, but will offer SFA difference in stopping power. Dont know anything about your pads, but you could try some A1RMs which are fine for me track work (on the G4 330mm kit) so should be more than enough for spirited street driving. I prefer not to use them for regular street driving, but many do.
Is the factory brake ducting in place?
Brake fluid is hygroscopic (except DOT 5 which is silicon based), the older it is, the higher the water content. Standard DOT 4 boils at around 220C, good fluids boil at around ~270C, the top end Motul RBF600 boils at around 315C while water boils at 100C. Once brake fluid boils it's completely useless as air is introduced in the lines, and putting the brake pedal flat to the floor won't do anything.
Moral of story, change brake fluid when you do a big change like change rotors/pads, and especially change it before a track day.
You're probably using the wrong pad more than anything
http://project-mu.co.jp/en/products/pad_mspec.html
Rated to 500C - this would be sufficient on a moderate hard driving around the street, definately wouldn't survive track abuse
You need to go to something more track focus such has HC+ or even Club Racer or MAX700/900i
Its got to be your fluid. No new pad/rotor setup will give up like it did with you. Even running old jap spec pads i could stop the car. So logically thinking whats the most important thing between your pedal and calipers? Brake fluid!
Im using dba 4000's with remsa pads and it stops on a dime.
The fluid could be stuffed, but the billowing smoke is definitely overheated pads. 500 deg C is a pretty low temp rating, they're not even "sports" pads IMO.
Most likely boiled the fluid at the same time as over heating your pads.
The Mspecs look more like a street pad, i use Project Mu Bspec pads for the street in my GTR and have had the odd spirited drive and never had them fade.
I have even used them on the track, i did over heat them on the track but in saying that the brake pedal never hit the floor i just noticed that braking power had decreased.
Would definitely recommend Bspecs for the street or step up th HC+ but that might be a tad over kill as they tend to be noisy and dusty.
The club racers are not suited for the street at all, i use these for track duties and are fantastic once at temperature
Ye I somehow missed the 500 deg C rating when I bought them, and just read the street/sport part :I .... Load of BS if they claim they're good for anything close to sports driving. In my opinion theyre only good for cruising around town and even then, they're noisy as hell... So I've decided to do 3 things. 1.install nismo braided brake lines, 2. replace the brake fluid with something high performance, 3. upgrade the pads to project mu max700. I'll keep you posted on how things turn out :D
Just be careful with pads on street cars. They MUST work from cold otherwise you will have the shittest accident in the world when you run into the back of a car at 30km/h because the pads havent warmed yet.
Alot of pads (not saying this of the Project Mu ones you mentioned because I dont know) don't work worth a shit when they are cold.
Also Motul make good brake fluid.
FYI last time i checked motul is around $25 for 500ml and is rated at 310 deg C. Nulon Xtreme performance is $10 for 500ml and rated to 280 deg C.
For me the Nulon is good enough, and available everywhere.
Exactly.
It's what a lot of people don't realise. My Ferrodo DS3000 would take a food 4-5kms of stop/start to become moderately useful - before that, if I needed to stop in a hurry, wasn't going to happen and it's worse than a your average streer car by comparison.
To the OP - 15-20mins of hills run, it comes as no surprise you are having brake fade issues. Fluid aside, you simply do now have the heat dissipation capacity with stock sized rotors for that kinda work. If you do go again, expect to boil the fluid again would be my guess of how it will go down.
They wouldn't last 3 laps on a circuit (5mins), so going for 15-20mins on a hill run will be very hard on brakes.
You should've upgraded the rotor size/kit rather than buying new rotors/pads if thats the kinda driving you want to do.
Did you clean the rotors with brake clean before instalation, mine had a heap of protective "stuff" on them which needs to be cleaned off.
If that stuff has got into the pad it will wreck them fairly soon I believe.
As with most things it is possible that Im totaly wrong !!!!!!
Ash, even a quick 5 minute spirited drive causes this problem.
Exactly.
Even a quick 5 minute spirted drive causes this problem. Serious serious brake fade. I've heard of plenty of people using project mu SCR rotors on the track and having no such issue, so I've got my money on the probem being inferior pad choice and boiling brake fluid. Having said that I've just ordered nismo braided lines and uprated project mu HC+ pads, so we'll see how it all turns out :)
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
