I know this may be covered already but I have only found conflicting answers.
How can I tell if a motor is a RB25DE or a RB25DE NEO?
Where would a stock R33 GTS-T turbo be located?
What are the differences between the mentioned motors and the intake manifold, being a Y-Split or a single (as seen in most DETs)?
  • Like 1
The pictured manifold is from a DE Neo. That's the only engine that had it. The R33 RB25DE and DET both had similar looking single inlet plenums and TBs. The DETNeo also has a single inlet plenum but has a different TB. It has traction control, so there is a whole extra butterfly and motor to drive it upstream of the main TB. The crossover pipe is therefore shorter.
Neo DETs have an OP6 turbine housing. Of course these can be retro fitted onto older engines, so it is not a 100% proof of Neo-ness.
A stock R33 turbo would be located on the exhaust manifold, in exactly the same place as any other twin cam RB engine's turbo.
  • 3 weeks later...
As mentioned above, people retrofit and bastardise engines for all types of reasons.
Head Casting Numbers, Most conclusive method for identifying heads. there will be a casting version number next to this identification number. IE. 5L7 3 would be the third revision casting of an R34 RB25DE. MORE INFO HERE
Otherwise if you have just a block, look up the engine number and make assumptions based on that. FOUND HERE
I have updates for both the register & the casting page. Just so lazy to type it all out.
  • 1 month later...
Bump with a new question.
How to tell difference between R33 RB25DE non Neo to a Neo or DET? I have a hunch that I've got a DE sitting around but unsure if it's just a non neo DE or DET. To me they look identical but doesn't have a turbo exhaust manifold. Though when i bought this car in question, i found pieces if paper inside with PSI numbers and lap times, car had turbo timer and a racing clutch and pod filter. Everything says it's a DET but there's no turbo/turbo manifold so i think it's been converted to NA.
Nup. Turbo and manifold would have been sold off to someone or taken by original owner to use on another/next car.
I think the R33s had different sized throttlebodies between turbo and non-turbo. Not sure what sizes they are. If the engine still has its cross over pipe, then the BOV on it will indicate turbo engine. If there is a water feed pipe from the beack end of the inlet manifold water plumbing around the back of the head to where the turbo would be, then that indicates turbo engine. Likewise the oil supply and oil drain back to the sump under the turbo.
  • 7 years later...
Sorry for bringing up a old thread but I’m having trouble identifying what engine I have.. is it a neo or s2? It has a plastic cas for a neo, turbo is a 45v4 , 75t block, no igniter on back of the block for coil packs..  I don’t wanna start spending cash until I know what parts to buy.. cheers ?
Edited by Smokey_1507
There were a few "transitional" engines that had the Hitachi CAS but were not Neo engines.  My theory is that you can tell by the ECU plug. The R33 is slim and has two rows of pins. The R34 (Neo) has 3/4 rows of pins. I used to know the colours  of the plugs but maybe someone else can tell you.
  • Thanks 1
Vct connector is heaps different, pre neo has external Vct drain at front exhaust side, that should be reasonably obvious.
Coil packs bolt in differently
What are you buying?
  • Thanks 1
Cheers KiwiRS4T, next time I’m back home I’ll check the ecu plug... the more I look at different pics of neo’s and s2’s I get confused at the differences!!
Ben C34,
I’m looking at service parts at the min, timing belt, water pump, spark plugs.. I’ve just got the car back from the painters and had an arch, side skirts, front and back bumpers fixed and painted.. I’ve just put a custom stainless exhaust on from the cat back ( sticks out a little too much, may take it back a little bit!) the next big thing will be injectors and turbo + link ecu and a tune to see what it puts out.. I’m not looking for crazy power.. it bothers me that I don’t know if it’s a neo but when I’m home I’ll check for the vct drain and ecu plug!
i have kinked tension rods, rear camber arms, toe rods, traction rods ready to be fitted when I get back.
the video it sounds like something is slipping in the engine, possibly a belt or could be bad audio but I heard something that doesn’t sound right  ?‍♂️
This theory is flawed, especially if a moron (like myself) has put a R34 NEO motor into their R33 using the R33 loom & plenum :)
Best way is to locate the front passenger side head drain, it's non-existent on a NEO.
  • Thanks 1
Cheers I’ll check it out or get someone too ASAP!!
  • 7 months later...
bro i’m looking for like this one intake manifold
how can I fond one for my RB25de neo?
thank you
  • 2 years later...
@Ben C34 so does this mean i have a neo? I recently took out my CAS to paint as well and someone told me that it was a neo CAS but when i bought the vehicle (A31 cefiro) i was told the engine was just a Rb25 s2
Edited by Quincy
49 minutes ago, Quincy said:
ooh so i got a neo head on a regular De s2 block?
Would be very unlikely. Neo combustion chambers are about 10cc smaller than the vanilla 25s, and the compression goes through the roof. Neos use RB26 rods and different pistons, with the differences being in the height of the pin and the shape of the crown. There is less dome, so they don't stick up into the chamber as far.
  • Like 1
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
