I'm in a position were I've searched for 2 hrs now with no resault,
I need to know which afm wires to the ecu go to which map sensor
Eg does AFM ® which in the Nissan manual is pin 26(sig ground) and 27 (intake air signal) go to map sensor on port 3 or port 4? And which wire goes to which wire
Afm (nil) pin 34 (ground) and 35 (air sig)
® is afm closest to p/s reservoir this is by Nissan manual other afm is unnamed (lower)
I can't find a d-jetro instruction manual at all anywhere
My cars a r33 Gtr s3 I own all rb26 manuals so I got wire diagrams n shit but no apexi info and paulr33s site stopped updating info :(
Hope someone can help not getting a mech to do it I only trust myself on my car
Thanks guys
Ok thanks mate, there's one green one blue wire do they have a number or u can wire any of them to any afm sensor wire aslong as the vac line u put to the nipple corresponds to what afm wire you put to that sensor?
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
