Hi I am new in here and here is my story -
I hv a GTR 32 in Hong Kong which produced in Oct 91'.
I did ring some import garages and they that said it is not possible to import a GTR 32 which produced between Jun 91 to May 92 to Aussie.
This car rated at grade 4 when i bought it from Japan few years before.
Anyone knows if some way to personal import this car ?
Thanks for your help !
https://www.sau.com.au/forums/topic/413158-import-a-gtr-32/
HI Alex, welcome! If you have just moved to Australia and you're here on a 'permanent' visa (as in not here as a student, or on a working holiday or tourist visa), you should be able to bring it in as a personal import.
www.ironladyimports.com :)
https://www.sau.com.au/forums/topic/413158-import-a-gtr-32/#findComment-6611922
Due to the emmission control in HK , GTR 32 can't pass that standard unless the car produced over 20 years and treat it as a classic car , then, the emmission inpsection could waived in HK. That is the reason why the car only registered less than one year even i bought it on 2009.
https://www.sau.com.au/forums/topic/413158-import-a-gtr-32/#findComment-6611930
Just successfully brought in a Porsche but it was an '88 so got it in on the pre 89 'Classic Car' concession. Unfortunately this wont be available to you but give the DOT a call they are actually surprisingly helpful.
https://www.sau.com.au/forums/topic/413158-import-a-gtr-32/#findComment-6615245
  • 3 weeks later...
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
