hey im hoping somone on here can help me. I have a rb20det i have had sitting for a year or so now ive finally decided to get it going. It is hard to start sounds like it wants to fire but wont and when it does it just coughs and splutters . the only way to rev it is tapping the accelerator on and off lightly or it will backfire and die. When trying to rev it studders and has crazy backfires it alsowont rev higher than 2500 if you can manage to get it that farwhich i think is limp mode. I beleive its running rich as it fouls the injectors and blows black smoke
can anyone help or have any ideas cheers
Edited by _andrew_
https://www.sau.com.au/forums/topic/413167-rb20det-backfiring-and-wont-rev/
If it won't rev past 2500rpm i'd say the AFM's dead.
Have you changed plugs, fuel filter & fresh batch of fuel if its been sitting for a year? Oil too for that matter? Give it a good service before trying to get it going after a year.
now it wont start at all cleaned the plugs that were fouled up
its getting fuel and spark
and i have installed new plugs new fuel , ic piping is all good
and yeah i think the afm is stuffed but it should run alright with the afm unplugged upto 2500
il try new fuel filter, afm and clean the aac valve would it run with no aac vavle(aac unplugged)
Edited by _andrew_
Have a look at the air regulator too under your throttle body that would be fair average I reckon have a look for the diy clean on here somewhere.
I'd deff be leaning to the AFM's rooted and I wouldn't be running it without the AFM.
With the AFM unplugged then it would definitely be reading zero airflow?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
