  • Replies 41
GRRRRRrrrrrrrr..... :rofl:
You'll keep.
Adrian
lol... i wont go near the track as ppl keep telling me ill run 11s, but i know for a fact ill be lucky to crack a low 13s...say hello to the space cadet behind the wheel and pedals :(
Im trying to get a 2 stage rev limiter for my car, so i can cheat when trying to get the thing to launch properly...and yeh i have read the thoughts of others on this, but its my car, my coin, and the engineering of getting something like this set up and working well appeals to me more then the pedal work involved....
So what was that about the launch controller you were using?
Matt,
How are your gear changes now?
I remember you saying a while back (216rwkw) that you grannyshift a little. :(
Hmmm... I probably shift a little more like a mid to late 40yr old mum now, certainly not MILF quality either :rofl:
But seriously, I still shift a tad softly. Any drag meet that I get to 'drive' the car home from is a good one!
At $1500 a pop I wouldn't be driving mine like I hate it either. ;)
My poor ol RB20t gearbox has been on its last legs for quite some time now, its just waiting for something to push it over the edge.
I have just the thing :)
just like I'm "assuming" I can do better... You're "assuming" I can't.
Listen matey, I've done what I talk about. Have you? Let your timeslips do the talking.
Roy, IanH uses the Power FC Pro in his GTT. It has launch control built in. You can hold the pedal flat and it will only rev to the pre-set level.
Adrian
your drag strip is concrete? hmm..
hard to tell from the vids.. just bouncing off the rev limiter probably chokes the car a bit after launch wouldn't it?
I think one launch in your vid was a low 2.x time which is not too bad.. should be able to get you a mid-13 from what i see from the SAU list if everything else is right.
What types of modifications dso you have on your car? Doesn't really seem to be taking off that quickly after the launch really, i think the mid-range is letting you down. What sort of tune has it had? do u have a dyno sheet? Maybe its just building too much power up top-end and not enough down low-mid end?
I wouldn't worry about trying to perfect the car at this point in time.
The driver needs the work.
I don't mean that in a derogitory (don't knock the spelling) way but until he's running consistent times at the peak of the current set up which may be @ 13.5, then what has he achieved.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
