Big Brake Group Buy - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
  • Replies 143
im in for front kit 356mm in purple for r32 gtr
would be keen on the rear set pending price confirmation
re: pads, ferodo ds2500 better option or the d2 street/race option? car to be used primarily on street
Honestly the street D2 pads are fine for street duties 100% :)
Added :)
(will confirm rear pricing when i can)
Street pad was fine in my R33 GTR for hill runs and similar @ 360rwkw and lots of traction. Long as you don't ask 10/10ths for 10mins+ straight /w heavy braking, you'll be very happy :)
Put me on the list for sure for the 356mm front kit for my 32 gtr with the black anodized caliper and sport pad with the rear kit also. Plus I read you need a kit for the hand brake for the rear calipers I'll get that too!
Kit for the hand brake... I shall investigate this also :D
I wasn't aware it was needed - will follow up, likely in 8-10 days or so once we all get back from SAU Nats :)
I'm pretty interested aswell, can you get me a price on the 356mm rear for 32 gtr aswell when you have time. Cheers.
About the handbrake issue, the way I read it was that you will only need a hydrolic handbrake if you want to use this setup for drifting. Otherwise the calipers work like normal. Maybe I'll read that again....
I read the same thing. Standard handbrake setup works fine with the D2 rear kit, as long as you're not using it for drifting. If you are, you need a hyraulic setup and second caliper.
I don't have a handbrake, I have a foot brake. So no funny business in the whale.
Ok then fair enough I'm sure I read the rear kit is 304mm and requires the kit to make it work properly and it's about $200 but if I don't need it then even better.
Done!
Im off to SAU Nats, back in a week and will then work on pricing for rears with Import Monster & Andrew from D2
Cheers fellas!
in the mean time i can help with enquires about the product, i cannot confirm any prices because this is to do with Import Monster.
As i said earlier - same pad size as the AP Racing caliper in the 356mm size, I think the code is AP5555 from memory.
I ran the 356mm kit on the front only - without rears. It didn't affect the ABS at all as Skylines are far more front bias so rears are less important.
As for how the kits compare - They are no $7,000 Alcon/AP kit (which they are based off)... But for $1800 - a saving of $5200 - you can't expect it to be identical, but i can tell you it's near enough having driven a mates GTR recently who has a 356mm Alcon kit. I couldn't say there was a difference.
Pad/rotor material plays more of a part in that anyway.
There were plenty of cars @ WTAC for example with D2 or K-sport brake kits on them, all working fine :)
Don't want to interfere here, but Alcons don't have to be expensive http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html
Maybe they are not such cheap as D2, but I'm pretty sure quite similar.
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
