Deadly serious. Ventilation like that can be caused by a number of different reasons. Anything that runs methanol is going to vent like that and a lot that run E85 will also. It doesn't necessarily indicate there is a problem.
70% of our tuning is e85 and we dont see that unless the engine is built to loose.
It's pretty hard to build a loose engine.
Poor catch can setup, poor ventilation in general and lack of a PCV valve can all contribute to breathing like that (visual smokiness).
The vapor coming from most breather filters is mainly steam. You can see the 'smoke' doesn't make it more than about 3 inches away from the filter before it dissipates.
Paul's pretty anal with his clearences when he builds an engine....
Thanks guys, ill give the tuner a call this morning. I did think it was odd tp tale 2 hours that low on an engine that needs running in.
Was there any blow-by before you took it to the tuner?
im pretty sure this tuner is the one that told me i needed a surge tank and 2* 044pumps to run ethanol and make 300kw, so i never used them. How many tuners would even put the car on the dyno until it was atleast idling? from what ive seen its too expensive to have a car sitting and not being actually tuned.
Lol yes well I hold judgement and don't point fingers
You don't need to point fingers. Just tell him to run it in, not f**k around with the idle on a very fresh engine.
#1 way to kill a brand new engine = idle
When you say 5 year build how long was the engine sitting after build before you started it? It does look more like steam than smoke...take breather tank out n see if any water/condensation is visible..You need to get a bore scope and look inside before any hard running IMO....
Im under the impression that you dont want to idle car at all on initial start up, you need to load it up as soon as possible to ensure you get good piston ring and bore seal, if you dont load it up you will not get the "sweet piston ring/bore/hone seal" that is needed and you will lose any hope of getting it later as you will have worn down the hone.
My boat was run in hard on the dyno then the next day it went to the drags, that was two years ago and its still going strong after a heap of track days/supersprints/drags.
A old mate of mine use to race his bike (2 stroker) and he also rebuilt his engine, he would swap out the piston and ring and hone the bore, he would then thrash the hell out of it straight away, it never had a issue.
Starting up cars/bikes/any motor because "its been sitting for a while" is the worst thing you can do to a motor, you can prep them for long stints of inactivity which will be 100 x better.
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
