Deadly serious. Ventilation like that can be caused by a number of different reasons. Anything that runs methanol is going to vent like that and a lot that run E85 will also. It doesn't necessarily indicate there is a problem.
70% of our tuning is e85 and we dont see that unless the engine is built to loose.
It's pretty hard to build a loose engine.
Poor catch can setup, poor ventilation in general and lack of a PCV valve can all contribute to breathing like that (visual smokiness).
The vapor coming from most breather filters is mainly steam. You can see the 'smoke' doesn't make it more than about 3 inches away from the filter before it dissipates.
Paul's pretty anal with his clearences when he builds an engine....
Thanks guys, ill give the tuner a call this morning. I did think it was odd tp tale 2 hours that low on an engine that needs running in.
Was there any blow-by before you took it to the tuner?
im pretty sure this tuner is the one that told me i needed a surge tank and 2* 044pumps to run ethanol and make 300kw, so i never used them. How many tuners would even put the car on the dyno until it was atleast idling? from what ive seen its too expensive to have a car sitting and not being actually tuned.
Lol yes well I hold judgement and don't point fingers
You don't need to point fingers. Just tell him to run it in, not f**k around with the idle on a very fresh engine.
#1 way to kill a brand new engine = idle
When you say 5 year build how long was the engine sitting after build before you started it? It does look more like steam than smoke...take breather tank out n see if any water/condensation is visible..You need to get a bore scope and look inside before any hard running IMO....
Im under the impression that you dont want to idle car at all on initial start up, you need to load it up as soon as possible to ensure you get good piston ring and bore seal, if you dont load it up you will not get the "sweet piston ring/bore/hone seal" that is needed and you will lose any hope of getting it later as you will have worn down the hone.
My boat was run in hard on the dyno then the next day it went to the drags, that was two years ago and its still going strong after a heap of track days/supersprints/drags.
A old mate of mine use to race his bike (2 stroker) and he also rebuilt his engine, he would swap out the piston and ring and hone the bore, he would then thrash the hell out of it straight away, it never had a issue.
Starting up cars/bikes/any motor because "its been sitting for a while" is the worst thing you can do to a motor, you can prep them for long stints of inactivity which will be 100 x better.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
