  • Replies 61
Posted Images
update
sold stuff everything else available
300zx turbo bigger than stock $400 (deposit taken pick up saturday)
air box $70
wing mirrors
clear indicators
one piece dump pipe for a s2
d1 catch can and lines
rb25 loom spoken for
series one stuff:
i have a 98 rs260/gtr 5 speed box 1k
front head lights one has a crack that has been repaird $100 indicators $80
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7351.jpg
damaged on ( the other one is good)
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7352.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7353.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7491.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7492.jpg
entire s1 dash so make offers on shit you need
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7547.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7546.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7548.jpg
s1 g sensor $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7549.jpg
s1 carpet in good condition $100
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7550.jpg
trust air filters for a gtr motor $150
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7531.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7530.jpg
s1 front gard extender things $10 each
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7527.jpg
greedy radiator hard top pipe $30
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7525.jpg
radiator bottome bungs $5
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7524.jpg
sard radiator cap $15
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7523.jpg
radiator top tank brackets $15
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7522.jpg
radiator duct $30
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7521.jpg
bonnet struts $50
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7520.jpg
front door brackets $10
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7518.jpg
bonnet brackets $15
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7517.jpg
driver window controler $70
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7501.jpg
rear tail lights $100
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7484.jpg
fuel level sender $30
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7555.jpg
series two stuff
dead long motor $400 (make offers on bits you need)
complete engine wiring loom $100
neo computer $200
auto gearbox $400
spitfire coil packs $300( these have done 60k but in perfect condition)
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7608.jpg
r34 cas $80
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7609.jpg
strut brace $100
transmission cooler and piping $100
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7545.jpg
best pick i have for now
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7539.jpg
front mount with piping $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7541.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7542.jpg
s2 auto steering wheel with air bag $250
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7538.jpg
also got a rb25 air flow metre( pink label) and apexi air filter in good condition $100
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7556.jpg
gtr stuff
r32 gtr brake upgrade ( slotted rotors, endless pads and gtr calipers $400)
]http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7537.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7529.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7528.jpg
r33 gr rims (awesome condition with federal 595 rubber 95% tread $1400
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7535.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7534.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_7533.jpg
sold stuff
air box $70
wing mirrors
clear indicators
front pipe and dump pipes staino and in good nick $100
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
