Having a bit of an ongoing issue with starting my 34 and lookin to sort it out as its very frustrating.
This has only happened immediately after fueling the car, no other time-may be a coincidence however. Fuel the car up, go to start it and it turns over but will not fire.
Fuel pump is priming and when I removed the fuel hoses to engine there was plenty of fuel being sent to the engine/so it appears the pump is functioning fine "waulbro 500hp pump"
Have tried releasing fuel cap and starting to release pressure
Disconnect and reconnect power
Disconnect and reconnect ecu
Have just installed a new immobilizer/security ad it still continues with this one and prior one
Have pulled and checked all relevant fuses
Checked all plugs to coulpacks connected and the other loom plugs
There is power to dash and fuel pump
Have tried locking/unlocking with factory remote-(someone suggested that the factory lockbox may have some sort of "immobilizing" setting) using a different lock box.
I haven't checked if there is power to coilpack loom or injectors-havent had a test light handy at the time
Near new spark plugs
Coulpacks have not been playing up at all "spitfire"
Injectors have had no issues and were cleaned as flow tested around 5-8000 km ago.
Running standard ecu /nistune chip.
Fuel filter replaced
None of the above has made it start, in the end after wasting 20-30 mins each time checking everything and sitting around it just suddeny decides to start.
Has done it about 6 times at various fuel stations- did it lastnight at bp west terrace city, and last week bp victor harbour.
Finding myself a bit stumped- turns over but does not fire. I'm lead to think its ecu related or electrical. It may be coincidental it's happening after fueling up, but hasn't done it any other time.
Any one got any ideas or similar experiences??thankyou!
https://www.sau.com.au/forums/topic/413203-r34-starting-issues-ideas-anyone/
Absolutely no help at all, but my wifes old car used to do this literally from brand new....in the end it got to the point where you'd factor in the time you'd waste at the servo waiting for the car to get it's shit together and get ignition back. The dealer couldn't even figure it out.
Classic fuel vapour lock symtoms but you said you remove the cap and thats normally the fix?? It should start after that
(E fuels does that a lot in the heat)
Does it go woosh when you open the cap ? it shouldnt pressurize the tank that much ?
return flow line blocked ? Causing overpressure flooding of fuel into injectors , only happens when fuel is hot in lines? fuel regulator not working right ?
test cold , remove fuel cap and start it ? Works ? No then you have another issue like regulator or electrical gremlins
immobolizer wouldnt let you start it ever ? if that was the cause
Blocked or collapsed fuel filter , had a autobarn drift one seep fuel around the flange just lately
Could alway smell fuel but never leak ?
Bad fuel pickup that looses prime suction ? Long shot
Crushed fuel line under car causes air pocket randomly after driving ?
Too much fuel additive , excessive injector cleaner will do that , bugger to fire warm
If it starts after sitting I would say fuel related
If it starts random could be anything elctrical or fuel or both
Electrical only dont normally fix after time unelss the commection arcs enough to " temp fix"
Doubtful it's a air lock in the fuel? I've disconnected hoses on one occasion and it was flowing well, and reconnected. I'd imagine turning it over would force the air lock through the fuel rail and back through the return line to the tank?
Had the same issue with the last 34- now ice swapped everything-looms, ecu, engine,literally everything into the new shell so I've taken the problem over to the new car.
I'm using genuine fuel filter-replaced since the first occurance, standard fuel pressure reg. the fuel lines don't appear damaged or squashed-it's good for 300kw constantly and isn't restricted on boost in the slightest which u would imagine if the fuel wasnt getting to the engine.
Doesn't go woosh when I open cap-barely had a pressure build up in tank- tried with cap off and on. Starts fine everytime no hassles except for these occurances I'm randomly having.
Haven't been using a fuel additive or injector cleaner in tank. -always use premium- mostly bp if I can otherwise i have to use the alternatives. I find it odd that its after fueling-how is adding fuel to a tank which already contains fuel stopping it starting....must be coincidental??!!
Spoke to the fella who tuned it today and got a couple more suggestions:
Get a spare coil pack to plug into loom and test for spark/electrical current to establish if there is power to plugs,
Test the injectors also for power for the same reason- I guess these will both establish where the problem lies-igintion-ecu-looms-etc...
Possible faulty relay that's getting warm/hot and not functioning and failing to power ignition/coils/injectors/. Could make sense- allowing time for it to cool down to function but still strange why so random and non consistent
it doesn't appear to be fuel as the pump works and is getting fuel to the motor.
Going to try these suggestions, and anything else's people come up with. Really hard to diagnose when it happens randomly sometimes weeks/months appart. And very frustrating when I get stranded..
Any other thoughts or ideas on the matter il be interested.
Doesnt a buggered AFM have those symptoms?
Yeah pretty much except it would happen other places not just after refueling ? Unless that is just a random event
A single coil pack wouldnt do that loss of signal to the harness would
Or injector pulse not on the main harness?
Or ecu malfunction from heat ?
it needs to affect all of the coils or injectors at once not just one? just one it would still run , bad but run
does the car smell of fuel ( engine flooded smell?)
Maybe its not seeing the hot engine temp and choking off the air mixture to suit? flooding the engine in fuel ?
The more kw the engine makes the less drivability it has ! (There is a reason the engine is detuned for mass consumption- driveabilty in any condition ) anyway 300kw is running and if its not running it has zero kw so that doesnt matter
can you remember if the day was hot , over say 27c or humid ? or you drove up and down lots of hills at speed and pulled into petrol station without idle down to even out the engine temps?
fuel lines or filter to close to engine parts and fuel boils in those ? doubt it but no idea how you have it laid out ? Factory or otherwise?
fuel reg malfunction is still a possibilty as well , flooding the engine
Waiting for it to f*#k again so I can try a few things and so far it hasn't,
Fuel reg is standard Troy, and fuel filter and lines in same spot as usual. Afm is z32 and around 10000km old- would this stop it starting?i would imagine it would definately change the way a cat runs if its faulty but does it prevent starting? And it's a high chance it is happening when fueling out of coincidence.
It's happened different times- driving 3kms on a freshly started motor to get fuel, and after traveling 170km, with minimal boost..it's completely random and doesn't seem to matter how it was driven prior. Haven't always filled it, but it has usually been down to a quarter or sometimes just below when it has happened.
Got a few things to try, hopefully it happens again soon so I can start diagnosing it... Thanks for the feedback- the more things to eliminate the better.
sorry to hijack, but Troy or anyone, can you please expand a bit on this quote?
More or less
All major car companies detuned cars for many years to comply with
emissions 70-90's cars were bad
Insurance - quoted power was much lower then actual power
Fuel quality worldwide- tuned for the market to lowest quality in most cases
Maintenance schedules- dependability if buyers didn't change the oils etc on schedule the motor etc would last beyond warranty , just !!! Old timers remember when cars would die just after warranty expires Hyundai and mitsu was notorious for it on E fuels
All the jdm brands in the past agreeing to 206kw comes to mind
US companies quoting low power for insurance regs or emissions targets
A car you depend on should be tuned so you can trust it,, not jacked up to make tones of power at max revs on perfect fuel on cool days
But one tuned for hot/ cold , fuel batches poor, etc
That starts first click of the key
Many cars on forums quest for max KW but loose function except track or dyno days
Or torque for so you don't have to spin it up every little hill
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
