Import Monster Sauvic Deca Motorkhana - 8Th December 2012 - Entries Open
  • Replies 195
Posted Images
I'll be leaving from S.E. Suburbs at about 12:00pm on Friday, can meet people either in Vermont at that time, or Wallan BP at approx 1 -> 1:15pm
Anyone have a spare seat to deca? around croydon area?
If so, im coming to volunteer.
On the road handjobs/other negotiable.
Edited by longboy
Guest
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
