Hey everyone,
Seeing whats out there for swaps or cash sale for my R33 skyline, registered with RWC.
Will look at all decent swaps!
Here are the mods.
ENGINE, TRANSMISSION ETC:
* RB25DET series 2 engine (166xxx kms)
* 5 SPEED MANUAL
* FMIC
* T04E turbo
* Z32 AFM
* s/s highmount manifold
* 45mm aluminium radiator with new blue silicon hoses.
* greddy style plenum
* 80mm throttle body
* splitfire coilpacks
* custom 3" exhaust with screamer (all heat wrapped)
* 38mm Tial external wastegate with 1 bar spring.
* custom made stainless steel intercooler piping, all tig welded.
* extreme heavy duty clutch
* locked diff
* heavy duty clamps all round.
* Genuine nissan gaskets
* always serviced every 5,000kms or less with quality nulon products.
* 740CC fuel injectors.
* Apexi power FC with hand controller.
* Greddy profec B II digital boost controller.
* Turbo timer.
* HICAS lock bar.
* X-Force highflow cat.
* x-force muffler.
* short shifter.
* Gates racing timing belt (2,000 kms old)
* GMB high flow water pump replaced at the same time.
* replaced fuel hoses and vacuum lines along with clamps.
SUSENSION, WHEELS BRAKES ETC:
* Brand new rota wheels 18" with awesome offset.
* Greddy coilovers
* QFM A1RM brake pads all round.
* Workshop one 7mm steering lock spacers
* solid rear subframe bushes
* KKR Rear camber arms
* GKtech wheel spacers on the front only.
* forged wheel nuts
INTERIOR, EXTERIOR:
* mint condition interior
* new leather boots
* drift button
* alpine type r rear speakers
* sony xplode front speakers
* pioneer head unit
* HID headlight conversion
* White LEDs all round (number plate, parkers etc)
* factory Kit?
* dark window tint
* carbon fibre boot lip
* Copy momo deep dish steering wheel
* tinted windows
Personalised plates do NOT come with car.
Minor things that new owner may like to fix:
* slight parts of surface rust on rear wheel arches, cheap fix just have never worried about repairing it.
I am interested in swaps - will look at other imports, VIP's, rotors.....etc
Im sure there is more on this car than what i have listed, basically all parts have been installed within the last 16 months. the car was Dyno tuned by Gavin Wood where it made a healthy and safe 310HP at the rears on 1 bar with loads of torque, will make more HP with a bigger rear housing.
SERVICING:
I service this car every 5,000kms or 4-6 months, in the last two years of ownership i have put 6,000kms on the car but serviced it 4-5 times as i like to keep it fresh and well looked after. fuel filter, vacuum lines, belts, timing belt, water pump, radiator, radiator hoses etc, everything has been replaced within the last 5,000 kms.
https://www.sau.com.au/forums/topic/413234-qld-1995-r33-skyline-gts-t/
  • 3 weeks later...
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
