  • Replies 41
Hey all
I'm wanting to get a 600ish hp engine in my r33 gtst.. Price target 10-20k (20 is a push). is it possible? got a running rb25 decent intercooler, 3inch exhaust, good fuel pump and fuel pressure reg.
What would you do? ps i live in brisbane
I would sell it and buy one with the work done, or a lot of it done.
You won't do it for anything less than 30k reliably.
20k if you don't build the engine or gearbox
15k if you buy everything from ebay but then it could go either way - maybe it works, maybe it doesn't, maybe it costs you another 10k to fix all the bad stuff
Built 25/30, TO4Z, E85, + all supporting mods ( brakes, diff, fuel setup, manifolds, fabrication, clutch, exhaust, stuff)
20k should do it.
Or buy one built for less so you can keep your car for when the other one breaks.
yeah, i was talking bout building a engine not just bolt ons. I have been looking around the net and did find a rb30/25 on spool for 10k http://www.spoolimports.com/miscellaneous-short-engines/rb30det-complete-engine. 10-20k has gotta get me further then a big turbo, big injectors, ecu and a blown engine. Surely things haven't gone up that much
U would be surprised how quick all the little things add up when building a motor,
There is also a difference in having a built motor and building the correct motor.
Labour is expensive, unless u do it all yourself.
I honestly don't think u will achieve it on your budget, I know from my own experience how much building a motor and supporting systems cost n it always ended up more then what I budgeted for
shattered dreams
Not shattered, enlightened.
Mine pushing just over 500hp ATM on 98, all I need is bigger fuel system to run E85 for more powers.
My new engine set up cost around 15k, that was a built 25/30 with a steam pipe exhaust manifold, turbo, Ross balancer and CAS, and some fabrication and tuning.
BUT
At 500hp the traction issues with a RWD become blatantly obvious, useless power is useless unless its a dyno queen.
Remember though a well set up 500hp RWD car should do a high 10, or so Im lead to believe, mines run a 11.130 so there is hope.
Think, plan, appraise, plan, do.
yeah, i was talking bout building a engine not just bolt ons. I have been looking around the net and did find a rb30/25 on spool for 10k http://www.spoolimpo...complete-engine. 10-20k has gotta get me further then a big turbo, big injectors, ecu and a blown engine. Surely things haven't gone up that much
600hp...
$10K engine
$2.5k turbo
$1k intercooler
$2.5k E85 fuel system
$1k exhaust
$1.5k e85 tune
$1.5k ECU
20k adds up pretty quickly without even touching the gearbox/clutch.
400hp with bolt on's maybe a better option or buy an already built long motor.
20k will get you driving some pretty quick well built 32gtr's too
Edited by wedge_r34gtr
Do all the work yourself, you'll do it with 20k easy.
To be honest the thought had crossed my mind.. problem is.. ive worked on most things to do with a car but ive never done bottom end work.. How technical is it.. ps i am quite confident in building shit im just used to working from plans
Try n buy a locally already built motor, there is heaps on the forums
What happens if you buy a "built" motor from Japan n when it turns up u find its still a standard motor??
A low km motor is still a standard motor.
What ever u buy tho, make sure it has receipts n a reputable place who screwed the motor together
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
