  • Replies 41
Hey all
I'm wanting to get a 600ish hp engine in my r33 gtst.. Price target 10-20k (20 is a push). is it possible? got a running rb25 decent intercooler, 3inch exhaust, good fuel pump and fuel pressure reg.
What would you do? ps i live in brisbane
I would sell it and buy one with the work done, or a lot of it done.
You won't do it for anything less than 30k reliably.
20k if you don't build the engine or gearbox
15k if you buy everything from ebay but then it could go either way - maybe it works, maybe it doesn't, maybe it costs you another 10k to fix all the bad stuff
Built 25/30, TO4Z, E85, + all supporting mods ( brakes, diff, fuel setup, manifolds, fabrication, clutch, exhaust, stuff)
20k should do it.
Or buy one built for less so you can keep your car for when the other one breaks.
yeah, i was talking bout building a engine not just bolt ons. I have been looking around the net and did find a rb30/25 on spool for 10k http://www.spoolimports.com/miscellaneous-short-engines/rb30det-complete-engine. 10-20k has gotta get me further then a big turbo, big injectors, ecu and a blown engine. Surely things haven't gone up that much
U would be surprised how quick all the little things add up when building a motor,
There is also a difference in having a built motor and building the correct motor.
Labour is expensive, unless u do it all yourself.
I honestly don't think u will achieve it on your budget, I know from my own experience how much building a motor and supporting systems cost n it always ended up more then what I budgeted for
shattered dreams
Not shattered, enlightened.
Mine pushing just over 500hp ATM on 98, all I need is bigger fuel system to run E85 for more powers.
My new engine set up cost around 15k, that was a built 25/30 with a steam pipe exhaust manifold, turbo, Ross balancer and CAS, and some fabrication and tuning.
BUT
At 500hp the traction issues with a RWD become blatantly obvious, useless power is useless unless its a dyno queen.
Remember though a well set up 500hp RWD car should do a high 10, or so Im lead to believe, mines run a 11.130 so there is hope.
Think, plan, appraise, plan, do.
yeah, i was talking bout building a engine not just bolt ons. I have been looking around the net and did find a rb30/25 on spool for 10k http://www.spoolimpo...complete-engine. 10-20k has gotta get me further then a big turbo, big injectors, ecu and a blown engine. Surely things haven't gone up that much
600hp...
$10K engine
$2.5k turbo
$1k intercooler
$2.5k E85 fuel system
$1k exhaust
$1.5k e85 tune
$1.5k ECU
20k adds up pretty quickly without even touching the gearbox/clutch.
400hp with bolt on's maybe a better option or buy an already built long motor.
20k will get you driving some pretty quick well built 32gtr's too
Edited by wedge_r34gtr
Do all the work yourself, you'll do it with 20k easy.
To be honest the thought had crossed my mind.. problem is.. ive worked on most things to do with a car but ive never done bottom end work.. How technical is it.. ps i am quite confident in building shit im just used to working from plans
Try n buy a locally already built motor, there is heaps on the forums
What happens if you buy a "built" motor from Japan n when it turns up u find its still a standard motor??
A low km motor is still a standard motor.
What ever u buy tho, make sure it has receipts n a reputable place who screwed the motor together
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
