It has come time to sell my 180sx, I have owned this for almost a year now but due to work and life commitments it doesent see much use, I drive it from sydney to newcastle on weekends, mainly highway ks, A fair amount of money has been spent on this car and the new owner will get alot of enjoyment from it. As with all cars of this age there not perfect, the car spends week days in sydney(orchard hills) and weekends in newcastle.
ENGINE-
RB20DET
RB25 op6 turbo
3' exhaust with varex cannon
water to air intercooler
pod filter
custom made air box
gk teck oil cooler and relocation filter
alloy radiator
2x 12' thermo fans
SUSPENSION-
hsd hr coilovers
driftshop castor
driftshop camber
driftshop alloy collars
front strut brace
rear carbon fibre strut brace
custom made rear seat belt brace
SuperPro bushes
gk tech 5mm tie rod spacer
hyperflex polyurathane bushes replace all existing rubber bushes
white line front 27mm heavy duty blade adjustable for rb conversion
whiteline Rear Sway bar - 22mm X heavy duty blade adjustable
DRIVELINE-
rb20det gearbox
r32 gtr exedy sports organic clutch
kaaz 1.5way diff
BRAKES-
r32 gts calipers
r32 gts discs redrilled to 4 stud
BODY-
ca front bar
nismo side skirts
copy vertex rear bar
jap roof wing
flares rear gaurds
stretch front gaurds
dark tints
INTERIOR-
r32 gts front seats
saber oil pressure
saber oil temp
saber boost
saber water temp gauges
elevo racing style steering wheel
velo 5 point harness
stripped rear seats
battery relocated into boot
WHEELS-
rota rb wheels
fronts-
16x8 +4
20mm bolt on spacer
rears-
17x9 -13
for this price you will also get:
-A set of 17in rims
-A z32 afm with plug
-A plug in link ecu in rb20det housing
-044 fuel pump
-r32 gtr 444cc injectors
-r33 gtr cam shafts
-just jap rb cam gears
-arc bov
-pair of frp 25mm wider front guards
comes with rear seats and seat belts - not installed
PRICE $11000
contact pm or on 0431 445 349
cheers, dan
https://www.sau.com.au/forums/topic/413258-rb20det-180sx-fun-fun-fun-11000/
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
