  • Replies 42
I would get scat again but I can't find anyone that has them? Anyone know? Thats why I'm looking at these two,
Goals is for a daily driven rb25 with around 400+hp here and there, no drift use ATM will see the 1/4 mile maybe twice and a circite run here and there,
There are some small design differences but at that power level anything with the correct tolerances and half decent material strength (stock or better) will be fine. If those well known brands actually have the right dimensions for the RB then any will be fine (I tend not to trust the ability of Americans in general to measure metric)
Both Scat and Nitto are world class brands with long reputations.
For that power level I would just use stock rb26 rods
+1
For 500hp, stock ones are proven time over.
If saving money on Rods lets you spend elsewhere on a better turbo/manfold/porting etc - then that's by far a better way to be spending on the cost/gain scale
If I didn't already buy bearings, crank and rods I would of built a rb30 bottom but already spent $1000
Also I bought some
Nitto rods just to be on the safe side
What turbo does everyone think? I want it snappy and responsive... Gt3076r?
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
