I also spoke to Raj about compliance for my BNR32. Very helpful. He faxed me the entire v10 ADR compliance document so I could perform the easy stuff myself and leave the rest to him. :)
Going thru it, i've come across the following:
adr 7/00 hydraulic brake hoses - requests for SAE/FMVSS/DOT compliance. My car came with braided stainless steel lines. Will these need to be replaced?? hope not. :P
cheers
  • 1 month later...
  • Replies 145
Posted Images
  • 3 months later...
Hi, I just bought an uncomplied cefiro off a mate and Im getting it ready for compliancing in south Australia.
It has:
Side Intrusion Bars (do I need an engineers report?)
Child restraints
Fuel filler neck and sticker.
I need a tyre placard? (anyone got one for a cefiro?)
I need seatbelts (what seatbelts should I use for a cefiro?)
will coil overs pass regency or should I try and find some standard struts?
anything else Ill need?
in sydney you pay 1200(100 more if you want the blue slip) for a shop to do the same thing(about the same price you payed for all the things but you did them)
advantage i think you would get is you might use better grade oils
the main advantage to me would be that the car is with and u know exactly whats been done
  • 1 month later...
Does anyone know what year Side intrusion bars came standard in all cars by law??
Curious if a 1991 gtr would already have them? I thought they came in in a standard in 1990 or somthing
Also the best way to find and engineer to do the sign off is to just call dotars yeah?
Tryin to find workshops that would do S I bars in rockhampton is gona be HELL or impossible
Edited by andy25
Ahh thanks for that lads ^_^.. I knew it was somthing like that.. Another Q tho why would anyone bother welding them in when they can be riveted does it look just as strong? im almost sure all this has been brought up before so sorry
Depends on the engineer that signs em off. One of the ones we use prefers to have them welded in on both sides, and won't sign off on the car otherwise. Another gets em down from QLD, bolts/rivets em in and signs it off, although he won't sign off on it unless it was installed by him.
  • 8 months later...
hi
I complied my gtr last year in nsw
used a u shape bolt in bracket at the front so the door was not removed and L shaped bracket at the back with countersunk 5mm stainless screws that are hidden under the door rubber.
have to remove the storm mold and the window and window regulator
no welding on the car 2x 8mm holes drilled behind the front of the door trim and 2x 5mm holes drilled under the door rubber at the rear.
the bars are 25x50 rhs
the full length bar can be manouvered in through the top slot of the door after the window has been removed because the end brackets bolt on
it took me a week to do both sides including lots of time measuring and checking for glass clearance.
  • 1 year later...
hey fellas
im getting another skyline soon a 32gtr i hope depending on total cost involed
D.I.Y compliance is this still possible today,have laws an regs change so it can not be done any more???
if it can still be done where would i find the list of things that have to be changed????
also when they have all been done then what, do i still have to take it to a complier to get documentation?then is this when i got to rta to get rego?
thanks
Hi,
sorry, no more DIY compliance.
We do R32's (June '92 onward) for $2500 inc GST.
Located in Melbourne, VIC
best,
david
hey fellas
:P
thanks
  • 2 years later...
no, what you need is compliance and the CIN that you get from the complier. apart from that you need to check state requirements. in NSW it's a blue slip inspection. and 'engineering certificate' is a pretty general term and covers a lot of things. they are usually done to certify non-standard vehicle modifications though.
i live in qld and i just recently bought an 89 nissan infinity q45 uncomplied. it has been in australia since december 2004. im wanting to do an engine conversion in it and do away with the vh45 as its seized up. i wont be putting another vh45 in. i know the engine needs to be running for compliance. however does it need to be the standard one? also im looking at upgrading brakes/ suspension and putting in a rollcage. am i able to do all the modifications including the engine conversion then just see an engineer once? also can someone point me in the direction of everything thats needed to be done in qld for compliance purposes. thanks Dale
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
