Hey lads
So quick story:
Planning on selling the rig after christmas, so I took it to get a roadworthy check so I had a month or two to get it all shmick before I part with her :(.
anyway I was expecting a few little niggly things here & there, but was instantly reminded of why regular maintenance & fixing things straight away is so important - 3 items needed to pass roadworthy & comments from the tester telling me he can't believe the condition for a 14 year old car :)
anyway so this is where my dilemma begins:
It's a 1998 R34 GT Coupe (manual)
& to pass roadworthy i need:
- new windscreen
- new front shocks
- new front brake rotors
I know that the GT rotors are smaller than the GT-T, but can someone tell me a good bang for buck rotor they have used? & in particular who stock GT rotors, not just GT-T items? (don't wanna chuck supercrap discs on it because i still need to drive it until it sells)
My main issue is the front shocks.
I remember reading somewhere that either the front shocks are the same & the rears are different compared to a GT-T or vice versa...something to do with eyelet vs fork mounting tabs.
I also remember either the front or rear was the same as a series 2 R33 GTST (not 100% sure on that one)
Can anyone clear this up for me & suggest a good bang for buck shock which is similar to OEM (will not be replacing rears as they are perfect apparantly) or are the OEM items not as expensive as you'd usually assume?
Wrong section I know but saves me from another thread - anyone want to recommend a windscreen place in Metro VIC?
Cheers for any answers guys!!
Try ISC Coilovers. They're fairly cheap and they should be able to sell you a new pair of just fronts for under $800 inc delivery. Don't trust second hand shocks, I made this mistake a year ago and would never buy second hand shocks again. In the end I got some ISC's in the rear and they've held up since, cost me about $750.
http://www.isc-performance.com/ - give them a call and get a quote
As for the windscreen, I would call around for quotes in your area.
As for rotors, I've been looking for some myself for my GTT, I've been leaning towards getting DBA's over RDA's as there seems to be too many bad stories about RDA's not being as good quality and warping. These two brands seem to be the main choices for the majority of people, although as you're selling your car maybe just look at getting some stock replacements. If you decide to get DBA's, the front for the GT are DBA 4963 - check the dba website for local suppliers!
- Front brake rotors - Nissan dealership - I think they are the same as the A32/A33 maxima and non brembo V35 - Not expensive.
- Front shocks are the same as R34 GTt and R33 GTSt
- Rear shocks are the same as R33 GTSt
- Windscreen - Try to polish it best you can - get a bit more life out of it.
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
