Vin from The video Anyone in Syd wanna go see if it's really the same car? I always notice how quickly that bloke goes past the cluster and build plates, never lingering long enough for you to get a rally good look at the numbers.
I'm gonna go out on a limb and guess.
A metric f**kload less.
With all the driveby shootings in Sydney these days you could only hope that one day someones gonna hit the right target.
looks like its much safer to stick to a trustworthy importer and slowly search for your dream car than getting one from a dealer.. its blasphemy how these people are treating the skylines... :(
Edited by C4a0s
That MP III GTR in the video J_R32 posted has 154,874 KM.... Wonder how much it'll be once it gets here
Sinno, just curious as to how you got the actual km travelled of the Edward Lees car? i am really tempted to comment on that youtube video to warn any potential buyers. this sort of thing really grinds my gears
It's just going to take one thoroughly pissed off buyer who has acquired data from both the exporter (in Japan) and the importer (here in Australia) to take the said importer to court whilst holding a stack of anomalies.
Also included shall be a declaration of proof of odometer Kms as the car leaves the shores of Japan + proof of odometer tampering after arrival in Australia.
Such proof could very well be the painting of screws to the cluster with a dye + the pics of those said screws before and after.
Further proof could be a frequency operated hidden camera where the vid can be relayed to a receiving station. Oh dear, this is getting complicated now isn't it?
Not my cup of tea.
*Edit:- sorry I brought it up. > Might have to resort to baseball bat after all > Actually I've always loved to use a mace on a chain > Where can such an object be obtained?
From the Knight shop of course. Comes in one, two or three ball.
http://www.theknightshop.co.uk/catalog/flail-morning-star-ball-p-1991.html?osCsid=f7560e0b2e024c245e4b0bd7b41c1743
Edited by White GTS-T
They get to review all posts on that video before uploading. I've already left a couple which for some reason haven't been passed from the lying turds at Edward Lees.
Their time will come.
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
