Thought I would post up my thoughts from my last track day on Wednesday @ the QR sprints
Previously every track day I have been to in my V35 I have always left the car in D mode with the PWR button pressed as the triptronic mode was far too laggy to be of any use
I recently had the transgo shift kit installed and was interested to see what sort of a difference it would make
I found that there were some pros and cons when it comes to trying to get your quickest time with the shift kit fitted compared to stock
The kit was good in the fact that I could drive the car like a manual in triprtonic mode and actually benefit from some sort of engine braking + the shifts happened for the most part in triptronic mode when I wanted them to unlike how the auto box behaves when its stock
I also managed to shave .16 off my best lap time however the improvement is somewhat on the small side that it could be attributed to a number of factors other than the shift kit
The negative, although I considered it more fun than negative was that the harder/faster shifts turned the car into a powerslide machine if I wasn't careful or more so if I wanted it to when shifting from 2nd to 3rd. This was with 245 Toyo R888 semi slicks on the back :woot: not so good for lap times however
I'm half keen to take the car to a Friday night drift session with some stocko 17's on the back given how easy it was to slide with the semi slicks on
Don't forget I am running an LSD unlike 99.999% of the other auto V35s out there
https://www.sau.com.au/forums/topic/413332-transgo-and-the-track/
Luckily I had AWD, it loved the track, for about 2 laps before the trans went into overheating limp mode.
I don't think I would take a stock valve bodied car to the track though, the clutches would slip badly imo, causing more heat. Do you have a large trans cooler?
Have never been in limp mode cars been to 9 or so track days with around 20+ laps a day
Do run a trans cooler, dont think you would call it big but you can see the size in the pic + I run the best bang for buck cooling mod by removing the grill at the track so the car gets max airflow even tho it causes more drag
Also note that my tranny is going to be dealing with a lot less power than yours given you make double the power I do!!!
Edited by 180 wanabe
Hey you keep saying this.......but every coupe that I have done a Transgo kit with in Sydney has had an LSD. Infact I am pretty sure it is standard equipment on manual or auto. The only difference being that the manual runs a 3.538 diff ratio and the auto runs a 3.327(or something).
Who said that the auto's don't come with LSD?
With the RE5 the line pressure is variable, meaning at light throttle is shifts silky smooth but when you plant it the shifts are firm. Definitely great for daily duties but it needs to be installed as per instructions, something professional transmission repairers seem to have a problem with.
The trans can be a little clunky compared to normal, not all the time just the occasional harder shift at light throttle or sometimes when dropping it back a gear. Nothing to worry about though. The clutches will last much longer without the drawn out slop into gear the factory valve body has.
Which suburb are you in Norby?
id be interested to know what the transgo is like for daily suties? I.e ido a lot of stop start driving, does it thunk between 1st and 2nd with little throttle?
mine isnt transgo brand (its custom made), and it does hit second quite hard regardless of throttle position. but this is in a 4 speed...
Custom made means it has some locally wound springs shoved in the place of the stock ones. This does not = shift kit. Yes it bumps up the line pressure but... Transgo have obviously spent a lot of research dollars sorting these kits out, replacing various pistons, adding valves and upgrading springs, all of which gives it the perfect crisp shift imo. I'm certainly glad my transmission specialist didn't cheap out and manufacture his own parts.
im in Croydon North, im actually considering doing this mod. Just realised today the paint on my bonnet has been repainted and is all now peeling... if it isnt one thing its another with this f***ing car... i still love it though
Pretty sure MV Automatics are a bit more detailed than that
I was sure I had found something about the diff specs of different V35 cars a couple years back. I know that the old diff in my car was crap and constantly peg legged at the drags/lit up the inside wheel when going around a corner at the track
If you can find an auto v35 that can throw down 2 black lines at the same time with the stock diff ill take my hat off to it who knows maybe a factory option, either way viscous sucks balls
copy pasted this from another forum:
2003 sedans didn't have an option for VLSD
2004-2006 sedans had a sport package option which came with VLSD
2007 sport sedans have VLSD, base & journey have ABLS
2003-2004 coupes had VSLD if it was a Performance Wheel and Tire package option, which meant 18" wheels auto or manual.
2005-2007 coupes only those with the Sport Suspension Package had VSLD
*The 18" wheel option for 05/06 is only that, wheels and tires
VLSD became part of the Sport Tuned Suspension package for 05/06*
You hope.
I can guarantee they haven't put the same amount of R+D into their valve body upgrades that Transgo have. All I can go by is the local 'specialist' that makes his own springs, they aren't anywhere near as refined and simply bumping the line pressure gives clunky changes. If you are happy thats great but the RE5 is a completely different gearbox...
And a two way doesn't? Give me a new tight oem Viscous lsd any day over a clunky mechanical. (for street)
There is no adjustment as far as I know, they will probably need to take the shims out from behind the line pressure spring in the valve body.
Perhaps a slightly thicker transmission fluid may help slow the clutch actuation down?
The diff option list above is for USDM
Best I can do.
Unless you've got a manual or an auto with 'sport package' then only way you'll know is by jacking it up and throwing it in nuetral.
Open diff's can twin up in a straight line though - my R31 had an open diff, and from a standstill it would light up both - have videos from the drags to show it.
Corners were a different matter though.......single peggers all the way!
I've had cars with open, viscous, 2 way and helical lsds and I'd say the best all rounder is the helical
Nothing puts hairs on your chest like going around a large roundabout in the wet with a nice tight 2 way :P
I owned a celica twin cam powered KE30 rolla with a migged diff for a few years, you get over it pretty quick, especially in winter. My favorite diff in the wet is the single spinner, no chance of stepping out with spider gears front and rear. AWD FTW. :)
Best I can do.
hey mate just a quick noob question,
when I jacked my car up on a hoist, and in N, the rear right wheel spins by itself, if I put my hand to it and hold it still, the rear left wheel starts spinning,
what sort of diff do I have?
cheers
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
