Thought I would post up my thoughts from my last track day on Wednesday @ the QR sprints
Previously every track day I have been to in my V35 I have always left the car in D mode with the PWR button pressed as the triptronic mode was far too laggy to be of any use
I recently had the transgo shift kit installed and was interested to see what sort of a difference it would make
I found that there were some pros and cons when it comes to trying to get your quickest time with the shift kit fitted compared to stock
The kit was good in the fact that I could drive the car like a manual in triprtonic mode and actually benefit from some sort of engine braking + the shifts happened for the most part in triptronic mode when I wanted them to unlike how the auto box behaves when its stock
I also managed to shave .16 off my best lap time however the improvement is somewhat on the small side that it could be attributed to a number of factors other than the shift kit
The negative, although I considered it more fun than negative was that the harder/faster shifts turned the car into a powerslide machine if I wasn't careful or more so if I wanted it to when shifting from 2nd to 3rd. This was with 245 Toyo R888 semi slicks on the back :woot: not so good for lap times however
I'm half keen to take the car to a Friday night drift session with some stocko 17's on the back given how easy it was to slide with the semi slicks on
Don't forget I am running an LSD unlike 99.999% of the other auto V35s out there
https://www.sau.com.au/forums/topic/413332-transgo-and-the-track/
Luckily I had AWD, it loved the track, for about 2 laps before the trans went into overheating limp mode.
I don't think I would take a stock valve bodied car to the track though, the clutches would slip badly imo, causing more heat. Do you have a large trans cooler?
Have never been in limp mode cars been to 9 or so track days with around 20+ laps a day
Do run a trans cooler, dont think you would call it big but you can see the size in the pic + I run the best bang for buck cooling mod by removing the grill at the track so the car gets max airflow even tho it causes more drag
Also note that my tranny is going to be dealing with a lot less power than yours given you make double the power I do!!!
Edited by 180 wanabe
Hey you keep saying this.......but every coupe that I have done a Transgo kit with in Sydney has had an LSD. Infact I am pretty sure it is standard equipment on manual or auto. The only difference being that the manual runs a 3.538 diff ratio and the auto runs a 3.327(or something).
Who said that the auto's don't come with LSD?
With the RE5 the line pressure is variable, meaning at light throttle is shifts silky smooth but when you plant it the shifts are firm. Definitely great for daily duties but it needs to be installed as per instructions, something professional transmission repairers seem to have a problem with.
The trans can be a little clunky compared to normal, not all the time just the occasional harder shift at light throttle or sometimes when dropping it back a gear. Nothing to worry about though. The clutches will last much longer without the drawn out slop into gear the factory valve body has.
Which suburb are you in Norby?
id be interested to know what the transgo is like for daily suties? I.e ido a lot of stop start driving, does it thunk between 1st and 2nd with little throttle?
mine isnt transgo brand (its custom made), and it does hit second quite hard regardless of throttle position. but this is in a 4 speed...
Custom made means it has some locally wound springs shoved in the place of the stock ones. This does not = shift kit. Yes it bumps up the line pressure but... Transgo have obviously spent a lot of research dollars sorting these kits out, replacing various pistons, adding valves and upgrading springs, all of which gives it the perfect crisp shift imo. I'm certainly glad my transmission specialist didn't cheap out and manufacture his own parts.
im in Croydon North, im actually considering doing this mod. Just realised today the paint on my bonnet has been repainted and is all now peeling... if it isnt one thing its another with this f***ing car... i still love it though
Pretty sure MV Automatics are a bit more detailed than that
I was sure I had found something about the diff specs of different V35 cars a couple years back. I know that the old diff in my car was crap and constantly peg legged at the drags/lit up the inside wheel when going around a corner at the track
If you can find an auto v35 that can throw down 2 black lines at the same time with the stock diff ill take my hat off to it who knows maybe a factory option, either way viscous sucks balls
copy pasted this from another forum:
2003 sedans didn't have an option for VLSD
2004-2006 sedans had a sport package option which came with VLSD
2007 sport sedans have VLSD, base & journey have ABLS
2003-2004 coupes had VSLD if it was a Performance Wheel and Tire package option, which meant 18" wheels auto or manual.
2005-2007 coupes only those with the Sport Suspension Package had VSLD
*The 18" wheel option for 05/06 is only that, wheels and tires
VLSD became part of the Sport Tuned Suspension package for 05/06*
You hope.
I can guarantee they haven't put the same amount of R+D into their valve body upgrades that Transgo have. All I can go by is the local 'specialist' that makes his own springs, they aren't anywhere near as refined and simply bumping the line pressure gives clunky changes. If you are happy thats great but the RE5 is a completely different gearbox...
And a two way doesn't? Give me a new tight oem Viscous lsd any day over a clunky mechanical. (for street)
There is no adjustment as far as I know, they will probably need to take the shims out from behind the line pressure spring in the valve body.
Perhaps a slightly thicker transmission fluid may help slow the clutch actuation down?
The diff option list above is for USDM
Best I can do.
Unless you've got a manual or an auto with 'sport package' then only way you'll know is by jacking it up and throwing it in nuetral.
Open diff's can twin up in a straight line though - my R31 had an open diff, and from a standstill it would light up both - have videos from the drags to show it.
Corners were a different matter though.......single peggers all the way!
I've had cars with open, viscous, 2 way and helical lsds and I'd say the best all rounder is the helical
Nothing puts hairs on your chest like going around a large roundabout in the wet with a nice tight 2 way :P
I owned a celica twin cam powered KE30 rolla with a migged diff for a few years, you get over it pretty quick, especially in winter. My favorite diff in the wet is the single spinner, no chance of stepping out with spider gears front and rear. AWD FTW. :)
Best I can do.
hey mate just a quick noob question,
when I jacked my car up on a hoist, and in N, the rear right wheel spins by itself, if I put my hand to it and hold it still, the rear left wheel starts spinning,
what sort of diff do I have?
cheers
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
