So this morning I had the skyline on the dyno.
Usual mods:
Hks2535 turbo
740cc injectors and walbro pump
Powerfc
All the expected bolt on mods for an average reasonably quick Skyline.
Running at about 17-18psi
Has been street tuned so I really wanted to know the power figure.
Disappointing to say the least, only 164kw atw
I have taken the car down the drag strip here in Townsville and have run times of 13.5 @ 111mph and my best of 13.3 @ 109 mph
Which I thought, while an average time, not a bad mph.
Thoughts?
Edited by privatealpha
Not sure what that means?
Was really hoping to crack 200kw but fell short of that by a long way.
Car is pretty damn quick for only 164kw though....
Well either the clutch is slipping, wheels spinning or the power dies off massively due to the tune
Well either the clutch is slipping, wheels spinning or the power dies off massively due to the tune.
Edit: maybethe dyno operator has let the throttle off and let the power drop before ending the run.
12psi run - 130kw atw
www.youtube.com/watch?v=UITPXBKRLrE&feature=plcp
1st 18psi run
www.youtube.com/watch?v=HWTNCefhkS0&feature=plcp
2nd 18psi run
Makes a whole lot of noise for not much haha.
The 3 dyno papers is all I got.
I like to think of it as a really strong 164kw atw :)
Interesting enough, on another dyno
12psi is 180kw and on 14psi made 199kw atw.
You can see why I was really hoping to crack 200kw especially with a bit more boost.
Ahh the dissappointment.
Edit:
Actually just checked, 10psi made 180kw and 12psi it made 199kw.
6psi more boost and made less than what I started out at.
The evidence is there. Sometimes the answer is so simple you get confused thinking about it. I'll bet if you go back to the same dyno that showed a low figure and had someone that knows how to set it up correctly actually using it the results would be a whole lot better.
This may seem silly. But my car has a vtec controller, which I suspect is for the VCT. Car is using an rb20 ecu.
Its just set to max, didnt have enough time on the dyno to play around with it to see where it should have been set.
Anyone ever connected a vtec controller to their 25's?
I've made an identical turbocharger for the development of our SS1PU turbocharger last year. I've made 248rwkws it didn't produce much of a nice curve with noise dive after 6000RPMs. I believe the comp wheel is too small for a Rb25det, how ever would be a ok turbo for a Rb20det.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
