Badben your sig say's you drive a 32 GTR. You mustn't do much night driving.
Get any modern car behind an old R32 at night and the 32 driver is driving in his own shadow.
Unfortunately their headlamp design is 20+ years old.
Add the sad wiring design and you've got poor lights, especially on low beam.
But fitting 6500+ HID's is just asking for trouble from the law who can pick the way overblue colour a mile off.
And what driver wants to be blinded by road sign reflection from his your own lights.
Stay with 4300 max. on low beam only.
R31 projectors are better than R32 ones!
I have 4300K in my 32, make sure you aim the lights properly (should be juust below horizontal, as the car is low).
Heaps of glare, but that's just poor projector design to begin with.
I'm in the process of going back to halogens, going to test out a few bulbs.
BTW, if you have reflectors, I hope you're not using aftermarket HID kit. 'Blue Power' halogens work well.
The factory R34 HID's have a nice clean light cut-off, they don't dazzle at all. If you stick to 4300K bulbs and leave the level adjustment to the lowest setting you're not likely to ever get any unwanted attention.
That sux bro - I'm in the middle of putting GTR HID's in my ER34 :\ hope the same doesn't happen to me. On that note, if anyone has done this before can you let me know - i'd like to run a couple things by you as I'm having trouble.
Cheers.
  • 5 months later...
I know this thread is a bit old so apologies for necro posting but everywhere I search I see people repeating the same "must have auto levelling" line.
However, from the relevant ADR:
http://www.comlaw.gov.au/Details/F2013C00238
Vehicle Standard (Australian Design Rule 13/00 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles) 2005
6.2.6.2.1. In the case where a headlamp levelling device is necessary to satisfy the requirements of paragraphs 6.2.6.1.1. and 6.2.6.1.2., the device shall be automatic.
6.2.6.2.2. However, devices which are adjusted manually, either continuously or non‑continuously, shall be permitted, provided they have a stop position at which the lamps can be returned to the initial inclination defined in paragraph 6.2.6.1.1. by means of the usual adjusting screws or similar means.
These manually adjustable devices must be operable from the driver's seat.
Continually adjustable devices must have reference marks indicating the loading conditions that require adjustment of the dipped-beam.
The number of positions on devices which are not continuously adjustable must be such as to ensure compliance with the range of values prescribed in paragraph 6.2.6.1.2. in all the loading conditions defined in Annex 5.
For these devices also, the loading conditions of Annex 5 that require adjustment of the dipped-beam shall be clearly marked near the control of the device (see Annex 8).
Of course this doesn't automatically mean the R34's xenons are legal but at first glance they seem to meet the basic requirements of levelling (not sure about specifics like max. adjustments etc.) There is definitely wiggle room with regards to levelling requirements.
If I'm incorrect on any of this please let me know.
Don't know why I'm posting in an old thread as well or how you found this but some food for thought, some R34's with OEM Xenon headlights DON'T have the leveling switch where the switch panels is next to the driver window switch, then again some HAS. My car is equipped with it so I think that would be the bare minimum. Also have been told that there needs to be "washers" for the headlights, incase the dust can dazzle oncoming drivers..
Came across this thread looking for headlight parts for my R34. Agree that washers are required too, was just pointing out that lack of auto leveling isn't necessarily a reason for being defected :happy: .
Fair enough if that's the case..were these cars coupes or sedans? It just seems a bit odd because according to Nissan data, xenons + adjusters went hand in hand together and were standard equipment on the coupes, OPTIONAL package for certain sedans (see links below). That would lead me to believe any xenon cars without adjusters were not factory xenons, i.e. xenons were fitted afterwards by the owner (aftermarket kits or swapped with OEM xenon headlights), or with switches taken out (duno why somone would do that though).. who knows. But of course I could be totally wrong as I'm relying on the accuracy of nissan's own data.. :)
Sedans:
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=/search%3Fq%3Dnissan%2Bhistory%2Bjp%26safe%3Doff%26client%3Dopera%26hs%3Db4W%26hl%3Den%26channel%3Dsuggest%26biw%3D2560%26bih%3D1284&rurl=translate.google.com.au&sl=ja&u=http://history.nissan.co.jp/SKYLINE/R34/9805/SPEC/frame4d.html&usg=ALkJrhjf7Ao5yxBJiPHYxg09cx6_KcTWYQ
Coupes:
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=/search%3Fq%3Dnissan%2Bhistory%2Bjp%26safe%3Doff%26client%3Dopera%26hs%3Db4W%26hl%3Den%26channel%3Dsuggest%26biw%3D2560%26bih%3D1284&rurl=translate.google.com.au&sl=ja&u=http://history.nissan.co.jp/SKYLINE/R34/9805/SPEC/frame2d.html&usg=ALkJrhi1Hak3JHxDbRjCB-upgf_C8BIsvg
Edit: Series 2 page on the same website doesn't state risers with the xenons, not sure if just not mentioned out actually removed from the car. Have seen series 2 with the switch though
Edited by fusion07
Is there any chance you can just buy a pair of 4300k or lower globes, so they look more yellow/halogen like and HOPEFULLY it can pass? haha
How will testers actually test whether the light is HID or not? Because the factory ballast is hidden underneath the headlight...
i thought it was pretty obvious for a qualified person to be able to tell if it's HID or not. if you look behind the lights in the engine bay its totally different
The ballasts are also easily visible if you look from the middle where the Grille is towards the bottom of the lights, sticking out quite clearly
Philips 85122 is 4300K, be careful of ebay ones, most are fake. You can get 4300K from ebay as well for about $20 each. Alignment is usually slightly out on those ebay ones. The 85122 gave a better cutoff and slightly better spread on my headlights (not OEM, Morimoto projectors).\
It's pretty easy to tell whether your headlights are HID or not. Colour, warm up, sharp cut-off, blue cut-off line (which is what dumb arses running 8,000-10,000K bulbs want in their halogen reflectors).
Ahhh... Guess that wouldn't work then....
When I first bought my car (car was complied back in 2004 when compliance was strict), my headlights were converted to H1, ballast taken out, globe cover has a hole drilled to wire in the H1. But i eventually bought a pair of stock Xenon headlights. I think nowadays, you'd have to be real unlucky to get done for HID's... Unless you have some blinding 10000k purple HID's lol
I've seen way to many blinding blue/purple headlights on the roads to think the police aren't doing much. A factory set will hardly get picked on, unless the officer didn't really like you or your car. I've been through a couple of RBTs with my HIDs and they didn't even give it a second look (4300K, projectors, properly aligned so it doesn't hit them in the face like half the cars in Sydney).
Nothing beats OEM HIDs though. Takes like 5 seconds to warm up, and you get a nice white, non-ricer light with even spread and a nice cut-off.
I love my bi-xenons though.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
