As much as this is the FI section you have to agree this is where all the mech heads hang out.. nobody goes to the NA section to talk about building motors etc. That section is all about who has the best looking slow skyline.
a video thread is definitely cool.. like the dyno thread. This turbo setup will make you lol this hard.
I like the idea.
https://www.sau.com.au/forums/topic/413483-a-video-thread/#findComment-6620607
yeah dyno videos suck. seen one seen all. i dont even watch my own car on the dyno lol
I think a good reference video thread would be in car of the speedometer while driving on the street or track with a description of mods listed. Eg would be.. r34 gtr 2.8 -5 than you can compare with the next guy who has a standard -5 or -7. It would also make peoples choices easier who is thinking about -5 or -7 and you can compare the lag and how fast it builds revs ect
https://www.sau.com.au/forums/topic/413483-a-video-thread/#findComment-6628127
Yeah this is a good idea it will help those people make choice on what set up they want, if they arnt able to go for a drive in a car with a similar setup to get a feel for it. this will at least give them an idea of what it will be like.
https://www.sau.com.au/forums/topic/413483-a-video-thread/#findComment-6628166
Problem with this is if you have a decent after market ecu you can fudge the Tacho to make things look alot better than they really are, that also goes double when they show ecu data video captures for speed aswell..... Also put R32/33 GTR Front n rear diffs/gears in an R34 GTR like alot of Jap shops used to do and watch the speedo!!! Not to say way too many Dyno's DONT seem extremely generous, but IMO listening to a car on the DYNO once you hear "THAT NOISE" you know something special is on the rollers..... I think put any and all video's up, there's always gona be haters and admirers..
https://www.sau.com.au/forums/topic/413483-a-video-thread/#findComment-6628460
Why not go visit wasteland?
That way if some dick head decides to post something stupid ACA etc can't access without creating an account and finding the video.
Aka wasteland isn't viewable without a login.
I think this thread is just asking for trouble
But that's just my opinion
https://www.sau.com.au/forums/topic/413483-a-video-thread/#findComment-6636760
Nice video's guys.
I don't see how its asking for trouble if the video is of the speedometer? In video 2 its obvious he is at the track as well.
Feel free to move to appropriate section if you think its best though
https://www.sau.com.au/forums/topic/413483-a-video-thread/#findComment-6638434
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
