Hi guys just need advice on a couple of things:
1. My clutch fluid is dropping slowly. I have to top it up every 300ks or so. I think it's my slave cylinder as my master doesn't appear to have any leaks. However the slave doesn't seem to show any signs of leaking either but I really have to get under the gearbox and check, I'm just checking from the side. I do notice small spots of oil that has dropped onto the garage floor however and it is brake/clutch fluid. Anyone know where they usually leak from? Between pushrod and housing?
If i get this: http://www.trademe.co.nz/motors/car-...-531091958.htm
what do I do about it having no pushrod? Can I use the rod from my busted one? How do I go about pulling the old one apart and putting it in the new one then setting the right travel etc
2. My gearbox feels notchy during shifts, I think it has something to do with the clutch not disengaging fully maybe. Is that possible? Sometimes it's hard to put into first gear, it refuses to go in and I have to let the pedal out then back in a couple of times and it almost always crunches if the revs were high and I put it in reverse too quick. The synchros don't crunch into any of the gears at high RPM though and it goes into first just fine if I'm slowing down and changing to it. What do you all reckon?
3. Oh also. I want to replace my factory front pipe and de-cat. The problem is the only available aftermarket stuff seems to be stainless steel, from luxury sports. The cat back system I currently have is mild steel. Will the difference in thermal expansion between the two cause my gaskets to fail when things warp? Or will things be alright if I bolt it together very tightly and use rubber mounts to allow for some movement? I have no idea haha... Otherwise, does anyone know where I can get a 2.5 or 3inch mild steel replacement to replace the factory front pipe?
Thanks in advance!
https://www.sau.com.au/forums/topic/413486-a-few-questions/
Yes. Definitely get the hydraulics sorted first as this problem may go away. Check the gearbox oil level anyway tho.
Strongly recommend you do both master and slave at the same time. If ones dying the other will be ready to go as well.
Masters can leak out the back and drip down the booster (tho IIRC gtst doesnt have a booster) so i guess it would leak down the firewall in that case.
https://www.sau.com.au/forums/topic/413486-a-few-questions/#findComment-6620275
Hey guys thanks for your replies. I've been told I can get a mild steel one fabricated for a box of beers at a garage if I hunt around so that's probably sorted.
Today as I was driving barefoot for the first time, I felt a drip of something on my foot. Turns out it was clutch fluid, so now I know where the leak is from!
I'll hopefully replace that tomorrow. See if I can get my hands on a slave at the same time :) The supplier didn't know if he had any in stock.
I also do have to do gearbox oil, been putting it off for a while now. Will report back soon!
Thanks again you guys :)
https://www.sau.com.au/forums/topic/413486-a-few-questions/#findComment-6621662
ARGH ok first issue, the thread on the new master cyl was f*cked. The U bracket would not budge at all because it was seized on there. I have no idea how it happened seeing as I never even touched that section till I needed to adjust pedal throw. Anyway, it's getting replaced.
I have another issue, after bleeding the system. I started the car, it wouldn't go into gear. My slave cylinder only moves just over 1cm so I assume there's not enough throw. My pedal also has like half the travel it used to. So is my thinking right, if I turn the U bracket on the pushrod and bring it out more, essentially lengthening the rod, I'll have more throw so I can push the slave cylinder more too right?
How do I know if I'm adjusting it correctly and how much I need to adjust?
Any information will be awesome, cheers guys!
BTW I have read a heaps of threads on there about clutch adjustment and all that jazz, there seems to be a very knowledgeable member on here called elite racing. Hopefully if you see this, I would appreciate your input :)
Edited by r32obsession
https://www.sau.com.au/forums/topic/413486-a-few-questions/#findComment-6624061
Ah completely forgot about this, I've managed to sort it now and whilst doing it, what he said on other threads makes sense. So all solved! If anyone encounters the same issues I've had and needs help, feel free to PM me and I'll try help you with what I've learnt. I ended up ditching the factory lines and using a braided clutch line. Saved so much time trying to tighten the stupid flare nut going into master cylinder
https://www.sau.com.au/forums/topic/413486-a-few-questions/#findComment-6628878
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
