ANy scratches on them? i cant tell by the photos, unless you have closer pics to send to my email : [email protected]
If they are all in exc condition with no scratches il take them for sure, but Im in melbourne. Does $2750 sound reasonable? ill pay postage.
You can call me on my mobile to discuss further. Very keen on buying but will only buy on confirmation from you that there are not scratches or major curbing etc. cheers
Yes the wheels are still available, and yes I will answer all questions. Just be patient please, I do have to work during the day.....
The wheels have NO CURB DAMAGE whatsoever. Some very minor light scratches and small chips here and there as a result of general road use. Some cut and polish will remove most of this and only necessary if you are really pedantic.
The tyres should only be considered as temporary in my opinion.
I'll upload some more pics of closeups as close as my camera will go tonight....
I took the pictures tonight, but had the email I was sending to myself at home blocked as the files added up to 23 Mb!! I'll adjust our mail server tomorrow and try again , but I think I'll have to reduce the resolution so that people who request photos dont have download issues. The photos came out well however.
The tyres are Bridgestone Potenza RE040 245/40/18. There is about 2-3 mm of tread on two of the tyres. Probably about 1-2 on the other two, however the centre section is worn almost flat on those...I'd say they were probably over inflated. The pictures will show it all.
Apologies for the delay...I'll get onto it ASAP....
A close up photo package is now available for those seriously interested. Unfortunately it is about 14 Mb in size. I cant do much less without losing much of the detail that everyone want s to see. I'll email to interested parties. If you have difficulties with the size of the file PM me and let me know.....
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
