Hi guys and girls.
My check engine light came on Friday and has been off and on since. I rushed to my mechanic today to have a diagnostic test run and have found code 21.
Can anyone recommend someone who can help me out who won't stuff me around or rip me off?
I have an idea of what needs to be done but would like to go to someone who knows R34's well.
Unfortunatly my mechanic is unable to assist me further and I am looking to find another that I know people trust.
I would love to hear some positive experiences from more knowledgable enthusiasts such as yourselves.
Thanks in advance.
https://www.sau.com.au/forums/topic/413521-diagnostic-scan-code-21/
At work at the moment but from memory - consult error 21 is ignition, most likely coil packs?
PM sent regarding mechanic who has both, the knowledge and the parts readily available.
Cheers.
Just thinking - has anything been tried so far in an attempt to fix?
Let me know if you need a hand.
Edited by iwanta34gtr
If you're after new coilpacks I can't recommend yellowjackets enough.
Mine were on the way out, giving me a horrid misfire under any kind of load. Popped the yellowjackets in and it's been great since. $440 delivered if I remember correctly. Really simple job too.
Thanks guys! It's most likely the coilpacks unfortunatly. $$$ :-(
Organised to have her looked at this afternoon. Thanks Andrew. Going to get a professional to do it as I would probably do it all wrong.
Just want to pay the money and get it done and move on. :-)
I'll let you know how it all goes!
Thanks for all the help! :-)
Well my baby has spent the night at the mechanics. New coilpacks coming in today also having the sparkplugs changed while I'm at it. Wasn't too serious. We found that the coilpack for cylinder 5 was being lazy! Look forward to picking her up this afternoon! :-)
Thanks again for all the support. I hope to one day be as knowledgable as you guys. Clearly I have a lot to learn! :-)
Edited by Jennie 1990
Thanks Owen. I feel a bit better about it all now. Well the learning has begun! :-)
Today was a no go though. The parts came in late this afternoon damaged in transit. :-(
New coil packs on the way express good to go for tomorrow! So I'll head there again after work. Couldn't spend another day without her. Looking forward to tomorrow afternoon when she'll be back and better then ever!
Hey Marsss! Hope you're well.
Coil packs being sent from a supplier in Queensland not Japan.
I try to always keep an open mind but after doing some investigation I look forward to seeing what this afternoon has in store for me!
Nice one! and "overnight parts from Japan hey? yr doing well....
why do people call them "liners"??? :rant: they're not liners.. if anything, they're "lines" :domokun:
carry on
Why do people call service stations "servos" if anything they should be called "services"
Or even more so, bottle-o's, "bottles" makes a lot more sense!
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
