Hi all, I'm trying to fit an adjustable front swaybar to my GTS-T and the supplied bushes are too big for the factory brackets. Whiteline don't show a universal bracket with the centre ridge so I assume I'm supposed to use the factory D brackets.
Problem is I've cranked them up as tight as possible, I may have even threaded the hole, and there is still a gap. The bush is compressed super tight and the swaybar can still swivel so I assume function won't be affected. Anyone see any problems with leaving it like this? The front nut is done up tight.
Pics (blurry but you get the idea)
https://www.sau.com.au/forums/topic/413592-fitting-whiteline-swaybar/
Grind the Nolathane (or whatever material it is) as necessary until the D clamp is securely fastened as per OEM (small gap IIRC).
This will not affect the function of the sway bar. These chassis mounts are simply used to constrain the Anti Roll Bar vertically and longitudinally.
Edited by R32Abuser
On the GTR i dont recall having any problems doing up the D bracket on whileline adjustables. If the bolts aren't turning easily with the bracket that loose, then there's something wrong. I would take the bar off and run the bolts all the way into the holes to check they're free and easy all the way.
Thanks for the replies, I'll give it another go and if not grind the bush. The bolts run freely, I copper grease everything an run a tap / die over everything I remove to ensure they are good to go.
Alternatively a local guy can make me a D bracket. Pedders stuff seems pretty pricey over here in NZ.
Thanks, I looked into the KS6 but it doesn't have the ridge in the centre that the bushes have, and it presumes a flat mounting surface (which as the pics show it is not).
I had another crack today and ended up dremeling the bracket so got it all done up but this happened:
see the crease in the corner, not good. Checked the other side and its the same so I pulled it off and figured out the problem.
The bracket is staggered, with one side higher than the other. The bush fills the bracket to the lower side of the bracket.
The chassis mount point has a bump in the middle, above that point.
So what I'm going to do is spin the bracket 180 and put the slotted end forwards which will put the bottom of the bush level with the "bump" on the chassis. Then I'll get a spacer to go between the bracket and chassis and make up the gap on the backside. Plus a longer bolt will be needed. This will mount it securely without deforming the bush. Hopefully.
If you're using a 28mm bar, I'm already thinking that Heavy Duty links are required too.
I used HD links on a Whiteline RSB and one of the D brackets broke - and that's a Whiteline one!
I replaced them with Pedders D brackets and haven't had a problem despite hairpin bends at E Blaxland and Hawkesbury Hts. $20.
It's a 24mm bar, product number seemed to indicate a 28mm but my mistake.. I'm sourcing some longer bolts and will make the spacer out of either some hollow steel or just use washers for now.
Part number BNF28Z
B = Bar
N = Nissan
F = Front
28 = the 28th Nissan bar that has been designed (that one happens to be one of my designs)
Z = Adjustable
The D bush looks like a GTR one, they are different to the GTST. There should be a part number moulded into the side of the bush. Take a note of it and give Whiteline a call, they can confirm if it s a GTR or GTST D bush
Cheers
Gary.
Thanks Sydneykid, you're exactly right on the part number. I read somewhere the 2 digit code was the diameter but obviously that info was wrong!
Bush is 5093-24, I'll give whiteline a call tomorrow and see whats going on. Failing that as above I'll shim the bracket but I was surprised it wasn't a direct fit given how long they have been making these!
Right so whiteline say there is no 24mm GTR bush and that the bushes I have are correct. They also say that they have seen this issue once before and that the car had GTR brackets instead of GTS ones possibly fitted after an accident or something. I have another GTS-T shell in storage so I'm going to raid that and see if it all works out..
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
