In Grey, Will sell with Blue Slip.
$20k ono
Motor has been rebuilt in Japan? (unknown spec internals)
Looks like a new head too
HKS 2540 twin turbos
HKS Dump pipes
3 1/2 inch all the way back
Pod Filters,
Strut bars
Ajust suspension
Nismo Rear Diff
Bucket seats
Stripped out interior
Bolt in Roll Cage
Some parts of the Rear are in Primer, We have just had body shop fix up some minor rust.
Went very well around Wakefield.
Just done comp test - a cylinder is a bit low, a ring might be going.
You can drive it still and you wouldnt know - its not terminal but would need attention.
If your intrested - must come see and inspect.
Michael
https://www.sau.com.au/forums/topic/41360-89-gtr-track-car/
certainly is.
sorry dont have any Pics.
If your intrested in the car for real, you can come have a look. :)
Yes, it will be road registrible 15 year rule.
But it is best being a track car with the stripped out interior...
michael
https://www.sau.com.au/forums/topic/41360-89-gtr-track-car/#findComment-847777
certainly is.
If your intrested in the car for real, you can come have a look. :P
michael
where can i look at it
https://www.sau.com.au/forums/topic/41360-89-gtr-track-car/#findComment-848712
Hi Guys,
If you intrested i n seeing in let me know.
Yes Car has 15 year import aproval. Will be sold with a blue slip.
Price can drop a bit to take some parts off....
Car is in Sydney
thanks
michael
https://www.sau.com.au/forums/topic/41360-89-gtr-track-car/#findComment-849256
  • 3 weeks later...
Good day mate is the car still for sale. I have seen pics and have a couple of questions.Do u have all the stock interior to go back in or will it be blue sliped as a two seater.Right hand rear besides the lights is there something missing or just paint.Im tryn to sell my 180 at the moment but is this price neg i want hte turbos but what else can u take off to bring the price down. sorry for long post cheers!!
https://www.sau.com.au/forums/topic/41360-89-gtr-track-car/#findComment-880730
lol
he he he
yeah certainly is - had some light rust - so it was repaired.
Car now has a full interior - looks a million times better.
Price is negotiable....
Contact if intrested.....
Michael
https://www.sau.com.au/forums/topic/41360-89-gtr-track-car/#findComment-894092
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
