Hey guys
Just a quick queory on what most people are using to remove their oil filters, as well as do you remove anything from the engine bay before they take it out.
Whilst ive changed my oil filter without any issues in the past. This time round it seems completely stuck in place, my oil filter wrench has bent whilst trying to undo it and I just seem to be cutting my hands apart because I cant get good enough access and keep scraping on things. This is in an R33 gts-t. I NEED SMALLER HANDS.
Cheers. Luke
jeez that doesn't sound right!
For next time; get a Drift brand filter as they actually have a metric socket on their head... if you can't get em out with a socket set; then something is seriously wrong...
As for your current situation i'm not sure sorry.... maybe spray the damn thing with WD40 then run the engine till its hot and loosened? I don't really know..
Assume oil is empty from the block - get newspaper down under the filter, long screw driver and a BFH (big hammer ;-)) and smash screw driver through one side of the filter and out the other. Twist off.
Not my favorite way - but I've been where you are before and it works.
Edited by SMOKEYC34
Multi grips can work well, or a better filter wrench. The screwdriver through the side as a worst case.
I don't use Drift filters anymore due to bad experiences but the K+N ones are cheap and have a similar hex adapter on the top...
lol. I bent my filter wrench. cuz i needed a slight angle to have any movement. Generally use Ryco filters in all my cars.
Might have a look in the shops tommorow and see if theres a better looking one then the flimsy thing I have now..
Haha I could imagine getting myself in a lot of strife trying to use a screwdriver.
By hand generally. I've just stopped putting them on stupid tight. At worst I need a rag to grip it. I've noticed that oil filters are much harder to get off hot than cold. Which sucks, because mechanics 101 says warm up oil before dropping it. If possible loosen it off a little cold before warming the oil up to drop it.
Even when I found a filter that was too loose (and tightened it up) it still didn't drop any oil.
Hey guys
Cheers. Luke
Hand Snug is all it needs
Screw driver punched thru the case all the way thru or it just rips the case open
A ratching strap filter wrench if you can find one works well?
Don't do it up stupid tight in the first place and u wont have this problem. I find if u do it up as tight as u can with one bare hand is more than enough, no leaks and just as easy to undo next time! Just my 2 cents
^^ this is what i had to do on my GFs avalon, overtightened by a mechanic and i had to put a screwdriver through it as a last resort, luckily the filter is on the front of the block
I use different methods for different cars. My car is some of that non slip rubber matting and by hand, the missus car is the same, but sometimes requires the screwdriver trick because it's hard to get to. Mums car requires the screwdriver trick unless i have welders glove handy, due to the filter being under the exhaust manifold.
Also make sure that if you do need to resort to bashing a screwdriver through the filter, don't do it low down enough that you're going to go directly into the threaded shaft that it screws onto.
I ended up buying the following tool from Supercheap for about $15. Needless to say. The angles fit in perfectly for the R33. Took longer to get it out of the plastic wrapper then it did to get the oil filter off.
If you need tools to remove the oil filter, you're doing it wrong.
Lube the seal, hand tight = easy removal.
I go by this theory, but as i explained in my post above, sometimes getting them off by hand isn't possible because of position (such as being under a hit exhaust manifold). I only ever put them on by hand
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
