I am selling my 180sx as I am looking for a super clean r33 or 34 skyline ..
Mods are:
* sr20det red top engine
* t28 low mount ball bearing turbo (off an s15)
* sr20 computer with Nistune hard tune ECU
* ACL bearings, forged pistons, rods and rings
* BC coilovers front and rear, both height and damper adjustabld
* FMIC with polished piping
* Front and rear strut braces.
* Tomei adjustable cams
* Reseated valves
* Metal gasket kit
* Nismo 550cc injectors
* 750hp fuel pump and rising fuel rate reg
* Nardi drift steering wheel
* Drift oil pressure gauge ( have another spot for an air/fuel ratio gauge )
* Autometer boost gauge ( mounted in cup, on pillar )
* New aluminum radiator,with thermo and relocated aluminum overflow
* All lines have been replaced and are either braided, or blue silicone to match
* Pil catch can
* K&N pod filter
* R33 skyline front seats
* Fresh bare metal respray, sky blue with a light gold pearl and black bonnet and roof
* Koya wheels with good tread
* 11 months rego
It's running 13psi at the moment, but I have been told by the previous owner who done the work that on 20psi it had made 355hp .. I plan to put it on the dyno this week and see for myself and can provide anyone with a dyno read out
I am looking for offers around $14,000 but am definitely keen on swapping for a real clean manual skyline
If you need any more info, call or message anytime on 0402 493 150
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
