Just thinking out loud here.
The idea is to fit a VQ25DET into a C34
Why?
Something different
Prefer to run as manual RWD. Easier to do engine and gearbox driveline conversion
Target 250-300rwkw......can they make this much :woot:
I need to do some reading up on Vq25det mods etc.
I have 10 years Rb experience....no VQ25 knowledge
Main issues to work out
1. Pretty sure it will fit in between strut towers. Engine mounts to fab
2. ECU wiring issues....Do people have VQ25det wiring diagrams they can flick a copy to me?
Should I go stand alone ecu and be able to tune it than work with factory VQ ECU?
3. What manual RWD gear box and clutch etc.....All 350Z, V35 skyline stuff?
Any cheap gearbox options, but as strong?
4. Basic connection problems of water, intercooler, exhaust, intake etc.
https://www.sau.com.au/forums/topic/413655-installing-a-nm35-vq25det-in-a-c34/
  • Replies 61
Here is a VQ35HR into a 32 GTR. Going by the pics there is enough room to fit it between the towers, etc. I think the way he's done some stuff is a little naff, but it works.
http://zilvia.net/f/builds-builds-only/346234-retarded-vq35hr-r32-skyrine-build-20.html#post4842144
and first page is here.
http://zilvia.net/f/builds-builds-only/346234-retarded-vq35hr-r32-skyrine-build.html
Vq25det is already turbo. So compression is right, turbo manifolds etc
Can get a vq25det front cut for $1000
sell rb25det
vq35 is non turbo......add turbo or supercharger kit plus to buy engine equals $10K plus...
$ verse cents really
tring to keep to a cheap budget build
VQ35 will be easier from an engine management standpoint, controlling throttle, cams, etc.
Anything can be done with enough time and/or money.
I'd be doing VQ35 with VQ25 heads, and I think the turbo manifolds then bolt up?
Agree
Target 250-300rwkw on the vq25det...... fit a bigger turbo and injectors and fmic exh....easy.
Ecu is main issue
Neo Rb25det.....Nistune ecu....cheap good workable solution
The VQ25det manifolds bolt up to the VQ35de heads.
Just drop it in with either a 350z/V35 6 speed box or a 300zxTT box and adapter plate. You would be best getting a standalone ecu, Link, Vipec or Haltech but there are cam actuation issues to work through.
sell rb25det
Yeah fair enough, remember though that an m35 front cut, at least in australia, wont have a manual gearbox. I'm guessing that a 350z gearbox would be the best one to use, no idea what sort of price they go for though
Who makes the gearbox adaptor plates?
off the shelf or custom made?
Cam actuation....do mine like VCT?
Most aftermarket ecu's have a trigger to turn on and off
I suppose its not on/off, but varible
I had a similar issue once with a motec M4 on a black 20V 4age
I might grab the VQ anyway....workout the issues later
Can always sell it again if I do not use it or if its too hard
The adapter plates are made over in Perth somewhere, have a read of this thread...
http://www.skylinesaustralia.com/forums/topic/358412-z32-300zx-with-vq30-twin-turbo-conversion/
He will know where they came from...
As for the cams, they are constantly variable giving around 40kw more midrange in my car and making the turbo much more responsive. Well worth keeping the evct if you can, I know Trent (Status) got the Link G4 to work with a similar Vcam RB26 setup which proved it was possible, I guess you need to find a good tuner that doesn't mind experimenting.
Heres a crazy idea that could just work. If u could find a crashed navara with a manual vq40 in it, you might have a cheap way to do it. If you stayed NA for now you could convert with all the oem ecu and stuff. Even NA would b pretty good in a stag with the mountain of torque from 4 litres. No need for head swaps, sump changes or adaptor plates. Then just build it with a turbo later.
Engine fits between strut towers....done before in 32, 34's
Did not think about the AWD sump issue....thanks
So the RWD gearbox will not mate up with the AWD sump.....
The VQ25det alloy block should be lighter than the Rb25 cast iron block....right?
The stagea will be RWD, as lighter than AWD, plus the body will be a fair bit light too :whistling:
So might end up closer weight to a skyline coupe.....should make handling a bit better.
Thanks Scott for info
Well.....I bought a 80-90% complete damaged M35 2001 today....
I will strip it, sell off the parts I do not need and keep the motor....for something
Spoke with Mercury today
They are building a M35 Stagea with a Trust T78 and 6 spd 34 GTR box behind it
It all mounted in the car.....still AWD
Might go check it out tomorrow for a look
We've been discussing this build. Take some pics for us if you can.
Interesting time starting for you by the sounds of it :thumbsup:
If I go the VQ25det with a 6spd V35 box I will have to sort the speedo out as the C34 runs off the gearbox and the M35/V35 runs off the rear wheels
How do you do this in a C34???
The V35 6 spd is the same price ($1000) as a good R33/R34 RWD box. But the R34/R34 box needs a very expensive adpator to make it to bolt upto the VQ, but the speedo would be sorted.
Fould some VQ35 to Rb gearbox adaptors on US ebay for $1150 plus postage. Have not found a aussie one yet to compare price
Maybe cut and weld the bell housing like Mercury did on the R34 GTR box in the M35 would be cheaper....
Why can't I keep the VQ25det AWD sump? Do I have to change it to a RWD sump?
In 2 weeks I will have both the C34 and M35 cars to compare and probably answer some of my own questions.
Edited by darrinspencer
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
