6-speed never came in AWD and doesn't appear to bolt up to the RE5 transfer case thus the thought that you'd have to go RWD if you stay with the 6 speed.
Either way, interested to see which way you go Darren. Best of luck :)
  • Replies 61
Why can't I keep the VQ25det AWD sump? Do I have to change it to a RWD sump?
The starter doesn't line up as it's about 15mm out. The crank sensor mount is correct at least, unlike the pathfinder. The VQ30det sump won't work either, you need the VQ35de sump from the 350z or V35 if using the 6 speed.
Where is the link to the adapters? I wonder if that would allow bolting up the 33gtr box I have here...
Heres a link to a Vq35 to Rb20 box.....is the VQ25 the same as a VQ35?
They have listring for Rb25 boxes as well......but should be no difference....R33 GTR should be same
http://www.ebay.com/itm/transmission-adapter-bracket-VQ35-engine-and-RB20-transmission-/350536723090?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D3730567278744479374%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D350536723090%26
Ok AWD to RWD sump is clear now...Thanks
I was planning to run RWD if I go the VQ25det....the speedo it a pain thou with 350/V35 box.
The speed signal is taken from the abs computer from the wheel sensors in the m35, you will have to do the old magnet on the tailshaft trick and use a Jaycar speedo adjuster for the pulses or similar.
I will check out the links, thanks mate. :)
I was starting to think a Y33 VQ30det would be a easier swap being RWD, Nistune avaiable for the ECU, etc.
Have spoken with Nistune and they are looking into a M35 Nistune version....long way off yet thuo, only early days
I am no rush, engine is the last mod needed on the next build....bodywork is the priority. C34 donor car is already teaked with highflow and heap of other extras.
The M35 can sit in the corner until I decide to use it....
bahhahahahahahahahahaa
Don't hold your breath.
That is all. The ECU is a orphan.
I really love your idea with the car mate - and the can do attitude. I hope it becomes reality and something pretty cool.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
