December Novice Comp
Sunday the 16th of December
PTC Frankston, 2 Skye Rd, Frankston
Lifting starts at 12pm
3 lift comp, soft suits not needed
Cost is $25
Lifters competing
____________________
Nick Rankin
Will Grainger
Wayne Kollen
https://www.sau.com.au/forums/topic/413669-ptc-frankston-december-novice-comp/
do it! pretty cool to have a bunch of people to cheer you on, offer advice etc
I've been trying to make my bro-in-law do it but he's a big pussy... 115kg, strong, Romanian background but embarrassed by his crappy bench press... I told him nobody cares, its just for fun but can't convince him
lol at Nick
Simon was competing at PTC before it was PTC, in 2007
From memory, he deadlifted 240kg@78kg.
He also finished 2nd in one of my EPIC Strongman events in 2009
He came before the chicken AND the egg.............then lit up a smoke
yeah i was shit, i think my max ever was like 120 ha ah, i reckon i could push out 130-135 for a single atm.
Cant DL for shit anymore, concentrating on weightlifting now so pretty much just squatting and overhead stuff.
Would be fun though, no way i could get back under 80 though
Lifters competing
Novices
Athan
Jarrod Stoll
Hodgy
Pete Marrinon
Eddie Swan
Kyren Lazarus
PROS
Nick Rankin
Will Grainger
Wayne Kollen
Zoran Jankovski
Daniel America
Martin Nguyen
Up to 15 lifters now
Lifters competing
Novices
Athan
Jarrod Stoll
Hodgy
Pete Marrinon
Eddie Swan
Kyren Lazarus
Sam Boyce
Khao Do
Kevin Muhamadzen
PROS
Nick Rankin
Will Grainger
Wayne Kollen
Zoran Jankovski
Daniel America
Martin Nguyen
In Weight Classes
Womens 56kg class
Rebecca Gleich - 54.5 - 92.5/60/125 - 277.5kg
Mens 75kg class
Kevin Muhamadzen - 72.6 - 130/100/192.5 - 422.5kg
Khoa Do - 74 - 110/112.5/180 - 402.5kg
Mens 82.5kg class
Martin Nguyen - 79.9 - 180/135/250 - 565kg
Sam Boyce - 82.5 - 130/112.5/180 - 422.5kg
Kyren Lazarus - 79.2 - 142.5/85/180 - 407.5kg
Ethan Perera - 81.7 - 115/70/135 - 320kg
Mens 90kg class
Jarrod Stoll - 85.1 - 110/97.5/150 - 357.5kg
Eddie Swan - 83.5 - 85/80/135 - 300kg
Mens 100kg class
Daniel America - 95.9 - 220/147.5/260 - 627.5kg
Wayne Kollen - 97.3 - 167.5/130/230 - 527.5kg
Mens 110kg class
Nick Rankin - 105.7 - 215/147.5/237.5 - 600kg
Zoran Jankovski - 109.7 - 180/135/275 - 590kg
Will Grainger - 107.6 - 200/120/240 - 560kg
Peter Marrinon - 105.1 - 150/125/200 - 475kg
Mens 125kg class
Matt Delloste - 113.1 - 170/107.5/222.5 - 500kg
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
