Guys
I am considering selling my R33 GTST. purple/green in colour. This car is in good condition and will need finishing off. I am not desperate to sell and will hold on to it if I do not get what I am after and finish it myself in due time. Only reason for selling is time. This car owes well over what I am chasing so please be reasonable.
The car was used in drifting in the past and the occasional track use, however it is seeing more drag use, hence the auto.
Body:
in good condition, Front bar needs work, i will throw in a new front bar if the car sells. This colour can be painted edge to edge, so no respray required.
Mechanical:
307kw LS2 out of a 2007 HSV club sport sporting a 4L65E trans. TCI flex plate B&M quick shifter, launch control, tail shaft loop, lock diff, lock out bar, D2 coilovers, alloy radiator
Engine and trans is solid mounted in car. This engine conversion can be done legally as you can have a 7.0lr N/A engine in a R33 GTST, You would only need to install a rubber mount in between engine mounts to make it legal. Proflow fuel pump, E85 compatible fuel system.
Engine had 68.000kms on it the car has 140.000Ish kms
Interior:
All stock aside from the 6 point bolt in cage and driver seat. tinted windows.
Needs to be finished:
Steering ( I should be finishing this week)
Exhaust
Tail shaft
Wiring
Accessories
Driver seat requires mounting
Any additional you may want personally.
I can supply additional parts to finish such as 250 shot of nitrous by nitrous express USA, can also supply a 3100 converter, currently has standard converter, all at an additional cost
20inch konig wheels. Car currently has ACT rego
I am chasing around 16K as is. Again, I am not desperate to sell so please no silly offers.I can also sell less engine and box, or supply a LS1 and auto instead of the LS2 for a cheaper price. I can also finish the car to your specifications if required.
Please be patient with replies as I cannot always get on here every minute of the day.
Feel free to email me @ [email protected]
https://www.sau.com.au/forums/topic/413682-r33-gtst-ls2/
  • 1 month later...
