Mate has a R32 GTR who's been stuffed around by doggy workshops to the point he has no GTR to drive.
He's looking at spending up to $20k on an engine or a rebuild, in all labour etc. Obviously looking for supreme reliability so no second hand parts unless they are obviously just as good as new. Would consider a full engine but ones like CRD's is well over the budget or need.
He only has a standard engine, so will need computer, fuel system, turbo's etc.
Suggestions?
https://www.sau.com.au/forums/topic/413703-20k-for-newrebuilt-engine-options/
  • Replies 61
Hey John - check this site for a package http://www.lewisengi...category9_1.htm
Saw it on a similar thread recently.
Maybe the $13k package. That will have left over bucks for aftermarket ECU, fuel pump etc..
Plus the out/in costs and consumables
Just a thought.
This guy does good work - would post it to you as a short block or put a head on (for extra) if you want:
http://www.hytecheng....nz/p/sale.html
Actually the Lewis Engines might be easier for you if the quality is there.
I would think he would want a australian (prob Can/Syd/Melb) builder with a strong rep for everyday engines. Prefer if the one place could do everything, drop car off, pick car up when done & tuned.
Or just give a listing of the parts and work cost that needs doing and he can source a builder himself.
The biggest issue with engine builders is the time they take, i have used a few different builders and most have taken up to 4 months to get the engine back.
Worth the wait hen u see theresults but still. Long time.
See if u can get an exchange engine i fthe wait is an issue
^^ See above.
Too often i see guys get screwed around on workshops who decide to take up 5-6 big builds at a time and work on each one when they have some spare time.
Its understandable that projects like this take time but some workshops over do it. Heck ive had a forged rebuild "drive in drive out" done in 3 weeks including modifications to the head, all machining, upgrade to my fuel system (pump, injectors etc). Most people are lucky if they get the same in 3 months !
I remember speaking to the owner of Lewis engines and at the time he said he can have the motor turned over in 3 weeks. Just ask him how busy he is. But yes workshops that take months coz they deliberately take on to much are f tards!
If your mate doesn't want to get stuffed around more I wouldn't recommend this builder.
Why's that? I am planning to get in touch with them sometime in the new year for a motor.. PM me if you don't want to say in public
Just a thought.
-7 garrets @ 21psi = 370rwkw
surely thats a typo
although its possible on e85
Edited by usmair
surely thats a typo
Probably mixed up the -5's and -7's
-7 garretts @ 21psi 370 rwkw
tomei ARMS twins @14psi 330rwkw
single TO4Z garrett @18 psi 390 rwkw.
-5 garretts @21 psi 340awkw.
NOTE: I haven't used LEWIS. So it's not an endorsement, just seemed to fit the requirement.
CRD did my build and yeah over $20k. I'm extremely happy with the result.
Not so happy with other business issue things and elapsed time for the rebuild. But hey - you get that and you just have to work through it.
330awkws at 18 psi on -7's (ESP tuned)
Could ask ESP (Qbyn) to get a price, timframe and make a judgement call if your comfortable.
I haven't had one built there either (like most others they would subbie some of the work), however I get them to do all my other work.
Reasonable on price and have met all their commitments to me.
Was a differen't story a year or so ago. They just overbooked and under deliverd.
Changes in the shop staff has made a big difference in my opinion.
Not had a bad experience since. *touch wood*
About to go spend another $5k with them.
Good thread to read, and when spending 20k on an engine, have a few good talks to your tuner. No half an hour later he has a 20k job sitting on his lap.
Talk to the guy building the engine, ask how many Rb's he's built. Or if he's been rebuilding ford's forever..
The most helpful guy will be the bloke actually rebuilding it. *not the guy at the front desk selling you shit*
Do yourself a favour go direct to the guy your dealing with, don't get a workshop who gives the job to someone else. It will take longer in the end. and you may not *not saying you won't* be happy with the end result.
Just my few cents from experience. worth the hassle if you want quality results "you" are happy with.
Thanks for the replies. I'll let him decide where exactly he goes.
More after suggestions for the build in the way of parts and the work needed. The built engine of "lewis" for 13K was something that was good to read.
I'm sure people have spent around this amount for a rebuilt/new engine, how did it go, what would you do differently?
fark... i get the shits over 2 weeks... never Waited more than 3.
If I could do it again, I'd seriously think about running a motor with stock internals. Beat the crap out of it, blow it up, rinse, repeat.
Dealing with engine builders generally sucks, and people generally overbuild motors for no good reason. What do you truly get with a built motor? piece of mind?
Edited by black bnr32
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
