Very basic question here so please straight answers. :)
Ignoring gear based electronic boost controllers, should max boost be equal across all gears (excluding first due to limited exhaust gases to make boost)?
For example, if I was to install say a Turbotech manual boost controller in my S15 should I expect to see 15psi at 3500rpm in 2nd, 3rd, 4th gear etc or would each gear boost differently?
I believe my boost controller is playing up so just curious on how it 'should' be working in theory.
https://www.sau.com.au/forums/topic/413710-understanding-boost-controllers/
I'm most interested in boost achieved in 2nd gear as that's the gear I tend to rev on the street. :)
If my car is tuned for 15psi @ 3500rpm in 4th gear then should it still make 15psi in 2nd gear?
Thanks for the replies guys. So it sounds like I will still hit 15psi in 2nd gear but it may be at say 3800rpm whereas it hits at 3500rpm in 4th gear.
If I replace my seemingly faulty HDI EBC with a Turbotech manual controller I'd like to see a very responsive 15psi in 2nd gear. I just don't want to have it set up in 2nd gear only to have it boosting higher in 3rd and 4th gear. My car is running a NisTune tuned for 15psi in 4th.
You will still find a proper EBC with gain controls will bring boost on a touch sooner than a turbotech ball bearing valve. I believe those HDi controllers only allow you to adjust a targetted boost i.e. duty cycle of the valve and not the gain
You're correct John. The HDI EBC merely had two turnable control knobs (one for low and one for high boost). You could increase or decrease boost by turning the knob. There were no other options like gain etc.
My new TurboTech v2 boost controller with the electronic missile switch arrived today and will be installed shortly. Fingers crossed it provides the excellent boost response and rock solid high boost that everybody raves about. PITS will be turning the boost back up to 15psi and checking the tune so I'll report back and compare my dyno sheet with the HDI compared with the TurboTech. :)
I am wondering whether I should block the standard recirc valve up (with a grub screw) to hold boost better above 5500rpm. During my original dyno run 18 months back you could see the boost would hold at 15psi until roughly 5500 and then taper off to 13.5psi from there.
You see, that's where you are thinking about it wrong. Your ECU is not "tuned for 15 psi". It is tuned for the airflow that it flows when you are at the highest load conditions. That would be 15 psi at max power revs in 3rd or 4th. But your ECU and the tune don't really measure or care about the actual boost. Just the power.
As to the boost falling off after 5500 rpm......that's nothing unusual. No boost controller can overcome what happens when you try to shove a crapton of gas through a small exhaust housing. Boost tends to fall off under those circumstances.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
