Hi Guys,
I recently put a S1 R33 RB25DE in my R32 GTS25. Did manual conversion, brake upgrade, wheels, plugged in engine and she was running mint! Until we went to drive it.....has serious lack of power under throttle and "splutters" when you drive it. First thought was AFM or coils. Replaced both and still no change. Also replaced fuel pump and filter, checked O2 sensor, TPS and APP. Everything appears to be wired in correctly and no signs of any vacuum leaks. Im out of ideas! Any help would be much appreciated :-)
https://www.sau.com.au/forums/topic/413719-rb25de-conversion-problems/
so you just plugged it in with the existing harness ETC?
have you hooked up the alternator earth and all the other earth straps? forgetting those can have that sort of effect
if its the original harness, what did you do about VCT? just curious here.
Probably best for my partner to answer that one tonight lol. As far as i know he used the r33 loom and just wired in the r32 plugs where needed. I know he has hooked up the VCT and everything has been earthed (we double checked last night)
I was right, he has used the r33 loom with r32 plugs where needed, and has hooked up VCT. Plugging the VCT makes no difference to the problem either. Also eliminated any vacuum leaks. Partner is currently checking all the plugs he swapped over to r32 to make sure all the right wires are connected.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
